Power and gas loss
Old 06-26-2012, 08:45 PM
drewk03's Avatar
Power and gas loss
So I just bought a 91 pickup with 3.0 with 155000. Has new head gaskets and rebuilt transmission in the last 10,000 miles. Runs good but has horrible gas mileage 14 and under and just doesnt have the power that it should. It has problems going up hill and picking up speed at lower rpms. Timing and compression are good along with new plugs and wires and new exhaust systems including cat. Any ideas on wheat could possible be wrong?
Old 06-27-2012, 06:40 PM
TNRabbit's Avatar
1. Check for ECU codes
2. Probably need to replace the O2 sensor at a minimum. That will put fuel economy in the toilet.
3. READ the stickies at the top of this forum.
Old 06-28-2012, 12:33 PM
drewk03's Avatar
How exactly do you check for ecu codes? Did the o2 sensor felt like it helped out quite a bit. Took it to emissions today and it failed due to high CO reading. Possibly part of my problem? Any more advice?
Old 06-28-2012, 01:43 PM
BMcEL's Avatar
https://www.yotatech.com/forums/f116...tickys-242840/
Sleaker
08-26-2020 06:03 AM
raptor510
02-17-2017 07:11 AM
tj884Rdlx
08-28-2015 12:04 PM
pyramid
07-30-2015 10:05 AM
karbin
07-05-2015 11:37 PM
Quick Reply: Power and gas loss
