PCV Valve necessary
Old 10-01-2007, 10:46 PM
Kiff's Avatar
PCV Valve necessary
So when I did my ISR mod, i removed the PCV inlet to the intake and just put a filter on, but this weekend I removed my intake mani, and the pass side PCV hose that goes to the intake broke off. So for now I have just capped the hole in the mani. I'm wondering if this has effected anything because there is 1 vacuum line I am unable to hook up without killing the motor. I know the passenger side is actually a valve where the driver side is just a hole in the valve cover.
Old 10-01-2007, 11:04 PM
Ringmaster's Avatar
The PCV's function is to ventilate the crankcase, so not much pressure builds up and blows out seal's.
The valve in it is to prevent lighting up the engine, [backfire]
A breather would work, but you'll have to block off the vacuum hose, and hope that the crankcase get's enough venting.
Unlike the old "Roadraft" crankcase venting/breather's of 45 years ago.
Old 10-01-2007, 11:07 PM
Kiff's Avatar
well as it sits right now, the pcv valve is venting to the atmosphere, the hole that it's suppose to connect to in the mani is capped.
Old 10-01-2007, 11:11 PM
Ringmaster's Avatar
See if You can add some type of breather on the valve so it doesn't suck in dirt/mud/crud.
Chevy had a plastic/nylon breather in the air filter housing, on all the cars trucks in the 70's see if You can dig one of those up.
edit: It was the intake breather for the PCV system on those old hummers.
LotOMiles
09-14-2015 11:45 PM
ac7822
09-11-2015 08:49 AM
Boomer8404
09-10-2015 09:01 AM
idadan208
09-07-2015 09:06 AM
Quick Reply: PCV Valve necessary
