passenger side leak !help!
Old 08-19-2008, 04:35 PM
pntbol11's Avatar
I've got an '86 4wd and whenever it rains the passenger floorboad gets soaked. I've checked all the seams in the door, windshield, etc. Is there anywhere toyotas generally leak and if so what's the best way to fix it?
Old 08-19-2008, 04:55 PM
xXbrutalXcoreXx's Avatar
i have an 87 and have experienced the same problem but only when i go through the carwash. haha it isnt fun. if you check under the hood where the hood itself is mounted there might be a small crack that will let water through. tell me what you find. =] if that description makes no sense then i can post a picture of what i am talking about for you.
Old 08-19-2008, 06:05 PM
PCE91V64x4's Avatar
Could be a leak in weather strip, window moldings (side or windshield) or the antenna mount. Well, lots of other places as well, but I would start there.
Old 08-19-2008, 06:11 PM
Myron's Avatar
i have that same problem..but ONLY WHEN THE AC IS ON water leaks on the floorbed....any ideas on that
Old 08-19-2008, 06:14 PM
InternetRoadkill's Avatar
The water from the A/C being on is from a blocked condensation drain.
The yota windshields are notorious for rusting underneath and developing leaks from rust holes.
abecedarian's Avatar
check the drain line from the airbox
Old 08-19-2008, 06:19 PM
Myron's Avatar
can anyone elaborate on that?
thanks guys
Old 08-19-2008, 06:27 PM
pntbol11's Avatar
YEa, I checked the windshield and the door and they are all dry. My a/c doesn't work. I think the antennae may be leaking. I replaced it a month ago and I sort of jerry rigged it sonow theres a gap showing in the mount.
Please elaborate on the airbox.
Old 08-19-2008, 06:37 PM
there should be a line from the 'airbox' (the box the fan and heater and a/c (if you have it) coils are) under the dashboard that exits the cab and drains somewhere near the frame.
lledwod
08-30-2016 01:03 PM
09-04-2015 09:27 AM
crashburnoveride
07-10-2015 06:39 AM
87blyota
07-10-2015 04:31 AM
87turboPA
07-09-2015 05:58 AM
Quick Reply: passenger side leak !help!
