Part number for exhaust studs, 22re
Old 09-29-2011, 03:05 PM
mountaingoat's Avatar
Got a brand-new Engnbldr Street RV head sitting in my living room, and I want to put all new Toyota studs in it for the exhaust.
Having a hell of a time finding the right Toyota part numbers for them though - can anyone help?
Also - it looks like the upper studs should be longer to accommodate the air injection manifold, is that true?
Thanks!
Old 09-29-2011, 03:11 PM
xxxtreme22r's Avatar
17159 BOLT, STUD(FOR MANIFOLD TO CYLINDER HEAD) Manufacture notes:EXHAUST MANIFOLD LWR 90116-10064 x4
17159 BOLT, STUD(FOR MANIFOLD TO CYLINDER HEAD) Manufacture notes:EXHAUST MANIFOLD UPR 90116-10067 x4
Old 09-29-2011, 04:05 PM
Outsane's Avatar
I ordered a set from LC engineering... not a shabby replacement
Old 09-29-2011, 04:23 PM
Thanks!! Much appreciated.
Old 09-29-2011, 04:35 PM
I did too, worked with my downey header with my tubes still in place.
Old 09-29-2011, 09:28 PM
wyoming9's Avatar
Smile
Are those the ones with the male torx heads ??
I could look back through invoices but have better things to be doing
Old 09-30-2011, 02:34 AM
92 TOY's Avatar
x's 1 zillion on the LC studs
Old 09-30-2011, 04:02 AM
I don't think so, those might be ARP or something.
IMO the LCE ones are better suited to headers which have a slightly thinner flange on them.
http://www.toyotacatalog.net/M1WebGe...5-4e8f9c45b1c9
The factory exhaust manifold studs have a shoulder in the center that can interfere with proper header tightening. For better holding strength, our 10mm x 50mm long, heat treated plated header mounting studs are stronger than stock. Includes: eight studs, serrated locking nuts.
Old 09-30-2011, 07:59 AM
angrybob's Avatar
I just ordered the TG header (on sale btw) and spaced on getting a new set of studs/nuts. Odd - the LCE kit shown above has all the same size 10x1.25x50mm studs. The Toyota system shows the attached pic.
It shows studs and bolts with 3 different fasteners.
Does anyone know the thread depth of either side of the LCE studs?. I have a set of new Toyota OE parts that are 10x1.25x50mm w/ lock nuts from a different project and can use those if the thread depth is similar.
Its all together still as I plan on doing the job this weekend so the obvious question of 'what came out?' can't be answered yet. I want to get a head start on studs if I can't use what I already have. The TG flange is 1/2" thick.
Any help would be appreciated.
Old 09-30-2011, 08:02 AM
One there is only two different sizes on the 89-95 22re's. I cannot confirm anything lower then that right now, I'd have to look it up.
Two I had no fitment issues with the LCE studs in my 87 22r.
Three that above photo shows intake manifold not exhaust manifold.
Old 09-30-2011, 10:47 AM
angrybob's Avatar
DOH! Thanks for the catch. Heh - I looked at the 17159 "bolt" and grabbed the image from the intake. The manifold appears to just use that one size of stud...as the LCE kit has. And good news is that what I have is the same
A slightly expanded pic is below.
Thanks again.
bigjstang
08-25-2021 12:41 AM
06-01-2021 01:51 PM
mskalmus
05-28-2017 07:51 AM
msane99
07-11-2015 08:08 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: Part number for exhaust studs, 22re
