Painless Wiring Hot Shot starter relay/bump start kit
Old Oct 14, 2006 | 12:07 PM
FR_Javier's Avatar
Finally got around to installing the painless wiring hot shot starter relay the other day. I had always had the intermittent starting problem on my '89 4runner and was tired of push starting it Works great and starts every time...even with a little odyssey PC680 batt.
Summit Racing Link
wiring is a mess...ill clean it up later.
Old Oct 14, 2006 | 06:40 PM
Yotatuff's Avatar
What exactly was your truck doing? I might have the same problem all it does is click.
Thanks
Old Oct 15, 2006 | 02:00 PM
FR_Javier's Avatar
sometimes it would start, sometimes it would not do anything when the key was in the crank position. searched a little and saw that this was a common problem with these trucks (have only had mine for ~8months)...also came across this very helpful site
http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
the hotshot relay works great....havent had a problem since!
Old Oct 15, 2006 | 02:31 PM
LOCKnGO's Avatar
Wow all I did was make a new 2Ga P+ wire and some new 2Ga grounds and my clicks went away. That is a cool remote start tho.
Old Apr 29, 2026 | 06:37 PM
Yotalife86's Avatar
Help need help installing hot shot relay
Any pics or diagrams will be greatly appreciated
Old Apr 29, 2026 | 07:09 PM
Discombobulated's Avatar
https://www.yotatech.com/forums/f116...runner-307493/
Old Apr 30, 2026 | 06:55 AM
dfarr67's Avatar
Cost me a good starter before I figured out it was a worn ignition switch. After I installed this kit, I liked it so much it went on other vehicles. Any vehicle that pushes alot of power through the igniton switch will benefit- this kit takes the juice out out of the ignition switch and adds a relay with decent gauge to the battery for the starter- as it should be from factory.
voiddweller
19
May 2, 2016 09:10 PM
stagger_lee
Mar 29, 2016 06:27 PM
bigblue82
10
Jul 6, 2015 08:27 AM
Corey
Jun 25, 2002 11:13 AM
