Oxygen Sensor Interchange
Old 10-23-2009, 06:51 PM
YFZsandrider's Avatar
I have a '94 22RE 4wd 5sp, what is the interchangeability of my O2 sensor with other 89 and up pickups. I found a wrecking yard nearby that has about a dozen trucks, and I'm really tryin to save money right now, otherwise I'd buy a new one.
Old 10-23-2009, 07:41 PM
bugs1961's Avatar
A quick check at Autozone.com showed a different part number from 89 as opposed to 94. You'd have to check each year to see if any are interchangeable. Good luck.
Old 10-23-2009, 07:52 PM
weaselman's Avatar
they are 29.99 from kragen auto parts. and 20 from a junkyard.
at least here in sac. might as well buy a new one?
unless u already checked into prices??
but if they are the same plug and same amoount of wire (s) then it should work just fine.
Old 10-23-2009, 08:08 PM
I ran a check at autozone's site and it came up with 8 different choices. My truck doesn't necessarily have a bad one, but the prev owner had it disconnected and the plug was resting against the tailpipe. I picked one up at a wrecking yard just to use its plug, if not the whole thing. I'll hook it up and see how it goes, but I'd like to know a part number that is the right one for my application... all I get at the parts stores is "Well, it's one of these?"
Old 10-23-2009, 08:12 PM
weaselman's Avatar
best bet would be to just bring in the old one and match it up. kragen tried to give me a three wire sensor with some totally different mount system and i told them no. and they said well its the only one that shows up. so i took it upon myself to use there computer and look it up myself.
then after i got my correct part, they asked me if i wanted a job.. hahahahah
jb451
7
10-07-2022 06:58 AM
Kreedy1
09-08-2015 06:33 PM
zz_denis
09-06-2015 03:43 PM
LJR
09-05-2015 06:02 AM
moparbay
09-03-2015 12:48 PM
Quick Reply: Oxygen Sensor Interchange
