over heating problem
I gotta 22re that over heats when i first go and drive it for a bit then after that it's fine even when I let it idle forever it doesn't over heat. Temp sensor faulty? I had a problem with it not reading so I replaced it with my old one of another engine and the gauge started working again. I also replaced the thermostat cause it was bad. I've heard of a two stage thermostat from the dealership that's suspose to be better than aftermarket in terms of over heating. I also don't have the fan shroud for the radiator but I'm not sure if that'll make any difference. Any input would be greatly appreciated. THANX!
for clogs? not yet maybe I should flush the whole engine out. It was a new motor I put in. I know the guy said it's been sitting around for a year or so. Thanx maybe i'll do that see if it helps.
fan shroud will help a lot with idling and low speed. if you can see crap in the radiator floating, or the coolant is more than a couple years old its worth doing a flush & refilling it.
the1998sr5
15
07-14-2020 08:35 PM
the1998sr5
07-16-2015 06:20 AM
