Oil Pressure Question - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-10-2008, 11:58 AM   #1 (permalink)
Fizboy's Avatar
When driving my 3.0 4-runner at crusing speed (60mph) down the road I notice that the oil pressure increases by about 5psi when I let off the gas slightly then drops about 5psi when I give a little gas. Do you think this is a bad omen?? Any thoughts.
I have an aftermarket pressure gauge installed on my dash. That is how I know the accuracy.
If this has already been answered sorry. I searched and found nothing.
__________________
92 4-RUNNER AKA: "THE MEXICAN TAXI"
33x10.50-15 BFG AT's, Downey 26mm torsion bars, Downey 3" kit on All Pro 1 1/2" coils, HyperFlex suspension bushing kit, flex-a-lite electric fan, NWOR hedders, Flowmaster, K&N, silencer mod, Yakima roof rack w/ Surco safari basket, Midland 75-822 hand held CB, etc...
84 PU THE EXTREME BUDGET RIG
Project Seven Rocks
63" Chevy swap, 4X innovations horse collar, 31X10.5 Interco TrXus MT, Buying stock in TG Parts. Slow go cause I am broke.
Fizboy is offline
Old 01-10-2008, 12:46 PM   #2 (permalink)
Elvota's Avatar
My OEM gauge always reads high when the motor is cold. The pressure will also read higher when the motor is spinning higher RPM's (foot on the gas), and very low at idle.
It has read this way with the 3.0 and now the 3.4 I have in there. Mind you, same sending unit and location is used for both motors.
I have heard that the OEM gauges are notoriously inaccurate though.
I realize this info doesn't answer your question directly, but you at least now know the pattern of another gauge is different from what yours is showing.
Whether this is bad or good... I am not sure.
__________________
1990 4Runner | V6 3.4 | 5spd | 240 someoddthousand miles | SR5 | SAS | RLS | 35's | ARB | TJM | 217 to 1 | W8000
- four wheels | three sticks | two hands | one trail -
visit the sticki chronicles
Elvota is offline
Old 01-10-2008, 04:15 PM   #3 (permalink)
86tuning's Avatar
oil pressure is a function of oil viscosity and engine speed.
higher oil temperatures = lower oil viscosity and resulting oil pressures.
higher engine speed = higher oil pressures.
When hot, look for around 10psi/1000 rpms. Anything less than that could be a problem. More than that usually isn't an issue.
HTH.
__________________
- Brian
84 toy pickup
mostly stock
86tuning is offline
Old 01-10-2008, 05:23 PM   #4 (permalink)
Fizboy's Avatar
Sorry guess I didn't explain it well enough. All the info about viscosity and temp. I know. What I am experiencing is the oil pressure increasing as I am unloading the engine at highway speeds then it drops as I load the engine. For example, If I am going up a slight hill and I have to put a little more gas to it (not down shifting) the oil pressure drop about 5 psi, but then when I am going down the hill and let off the gas it rises about 5psi. Speed and RPM stay pretty much the same. It changes when I put on or take off a little bit of a load.
Hope this is a better explanation.
__________________
Project Seven Rocks
Fizboy is offline
Old 01-10-2008, 06:17 PM   #5 (permalink)
It was clear to me. Have you considered that the gauge or sending unit may be bad?
Georgiadave is offline
Old 01-11-2008, 08:09 AM   #6 (permalink)
Fizboy's Avatar
Thought about it. You wouldn't think so since it is new. However I have bought many things new that were bad.
What I was thinking was that there could be slop in the main bearings or possible bad oil pump. So far this engine I bought from CNS motors is really starting to suck. I wish I had rebuilt the thing myself.
Thanks for the responces keep them coming.
__________________
Project Seven Rocks
Fizboy is offline
Old 01-11-2008, 09:52 PM   #7 (permalink)
Dirt Driver's Avatar
Send a message via AIM to Dirt Driver
I have been told that loose bearings can be responsible for the behavior you're experiencing. I had the same thing with a Ford 289. Oil pressure acted normal before the oil pump shaft broke and the bearings got hurt. After that, the pressure was lower and would drop if I leaned on the gas, yet come back up when I let off.
__________________
Aka Dirty Dude thanks to a4runnerfreak.
'94 Toyota PU-2WD, 22RE, 211,000 & counting.
I have some Fords too. Looking for a turbo 4Runner or FJ55.
Dirt Driver is offline
Old 01-12-2008, 07:50 AM   #8 (permalink)
nate V's Avatar
Sounds normal to me.
The pistons are very bad at sealing off the cylinders from the oil cavities.
With every compression and combustion stroke you will be getting some excessive blow by that will result in higher oil pressure. Thats just a fact.
Hope its not too serous.
__________________
1988 Pick-Up / 3.0 / 4:56 / 5 speed / 278k miles
"Drive it to hell and back"
nate V is offline
Old 01-12-2008, 10:02 AM   #9 (permalink)
Fizboy's Avatar
Yeah I hope it is not serious either. I have another $130 invested and the front of the engine apart for a bad upper idler pulley at the moment. The damn thing only has 30k on it and it went bad. Oh well Toyota may be great vehicles but like all vehicles they are money pits.
__________________
Project Seven Rocks
Fizboy is offline
Old 01-12-2008, 10:44 AM   #10 (permalink)
Maybe in the most technical and minute of scientific measurements, but in practicality that is NOT a "fact." On top of that, he said the oil pressure goes down when he gets on the throttle which is when cylinder pressures are highest. That's the opposite of what you describe. Besides, the crankcase ventilation system vents what pressure actually does make it into the crankcase.
Blow-by doesn't affect oil pressure unless you get a bunch of fuel in the oil and thin it out. If the engine isn't running seriously rich, then that's not the case. Being a low-mileage rebuilt engine and ASSuming the rings seated correctly, leak down should be well under 10%.
If the crankcase actually did get pressurized enough to see it on the oil pressure gage, oil would be blowing out of every seal on the lower engine.
__________________
Old 01-14-2008, 09:44 AM   #11 (permalink)
nate V's Avatar
Im sorry but blow by does directly effect oil pressure.
With regards to the oil pressure going down when the throttle is advanced, valves are more efficient at higher speeds.
Lets make this simple...how do you think your engine oil gets dirty with carbon if there is no significant blow by??
__________________
nate V is offline
Old 01-14-2008, 09:59 AM   #12 (permalink)
That condescending tone at the end is a nice touch. I don't need simplification. What I need is for you to clarify your definition of "significant blowby." It's not even clear if you're talking about oil dilution or thickening. A new engine does not have "significant" blowby. In addition and I repeat, the behavior outlined in the original post is the opposite of how you describe blowby to affect oil pressure.
__________________
Old 01-17-2008, 03:04 PM   #13 (permalink)
Fizboy's Avatar
Now kids play nice. Don't make me pull over. LOL
My intent of posting this was just to see if the numerous Toyota owners/ vehicle guru's on this forum had ever experienced this before, and if they knew a possible cause. So far I haven't had any significant problems related to this. I am just one of those people that are constantly looking for indicators to a problem so I can fix it before it brakes.
__________________
Project Seven Rocks
Fizboy is offline
Old 01-17-2008, 03:09 PM   #14 (permalink)
Staff
Lysmachia's Avatar
Send a message via AIM to Lysmachia Send a message via MSN to Lysmachia Send a message via Yahoo to Lysmachia
Yeah like blowing a head gasket? (ask me how I know). Those of us with the lamo 3.slow and no aftermarket gauge don't have the luxury of seeing what you are seeing. But I doubt it is predictive of anything as severe as a blown head gasket. However, you never know with a 3 slow....!
__________________
Molly
aka Lysmachia
93 4 Runner SAS (Tippy) - All Broken in Junk Yard Goodness
Get your 4x4 VIDEO pr0n here
Quote:
Originally Posted by leebee View Post
from this gray haired old red head to you, EGO BOOST!! you go girl!
Lysmachia is offline
Old 01-18-2008, 10:59 AM   #15 (permalink)
TC22RE's Avatar
I have the same thing happening on my turbocharged 22re. Not sure what it is. I've only got 50,000 miles on the engine. I've done a leakdown test, and a compression test, all are fine. No oil consumption, no "excessive blowby". Everything runs fine. I have a fairly new high pressure oil pump on there (installed about 10,000 miles ago), wonder if that has anything to do with it. I was worried at first but its been doing this for as long as I can remember with no problems so I've stopped worrying about it.
__________________
'94 Single Cab 4x4 Pickup
Turbocharged/Modified 22RE
SDS EFI System
Std 5spd
31x10.50 BFG's
TC22RE is offline
Old 03-02-2008, 10:24 PM   #16 (permalink)
Fizboy's Avatar
I have pretty much stopped worrying about it as well. I bigger fish to fry, such as putting a new knock sensor in and figuring out what else is going on with my engine. It's always the little things that get ya.
__________________
Project Seven Rocks
Fizboy is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Burning oil/oil pressure question on 3.0 coloradodragon 86-95 Trucks & 4Runners 5 11-03-2008 11:26 AM
Oil pressure question ken914runner 86-95 Trucks & 4Runners 5 08-14-2006 10:09 PM
Oil Pressure question. HurleyBoy 95.5-2004 Tacomas & 96-2002 4Runners 5 08-25-2005 03:44 PM
V6 Oil pressure question Silver_Truck 95.5-2004 Tacomas & 96-2002 4Runners 2 02-18-2005 07:17 AM
Oil pressure question Whitey 95.5-2004 Tacomas & 96-2002 4Runners 4 08-17-2002 08:01 AM
2009 InternetBrands, Inc.
