oil pressure
oil pressure
i changed my oil filter about 2 weeks after putting new oil in because of loss of filter wrench but drivng to car wash the gauge was really high never seen it that high. So i wash it off and started it up to leave and the gauges was barely reading at all. could it just be the sending unit or a serious problem
A sending unit can go bad at any time, i would try changing it first. If you drove it home and didn`t have any problems then it should be ok. I did have the oil pump go bad on my 86 4Runner, and i was lucky enough to catch it before it did any damage.
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Hot OP can look like it's not even reading... But a quick reference to THE OWNERS MANUAL and noticing if it's in the NORMAL ranges will, or should put yer fears to rest...
Anything not in normal is a cause for concern... But your light should come as well..
i used a manual oil pressure tester and at hot idle it was at 25 psi and at 3000 rpms it was about 70 psi i think that thats about right. what do you think probaly the oil pressure sending unit?
Odin
07-15-2015 09:28 PM
88yodabasket
07-13-2015 01:32 PM
