oil loss on 95 v6 p/u
Old 10-19-2009, 10:42 AM
jonmorgan's Avatar
95 v6 200k manual 4x4 p/u
she's losing oil- doesn't drip, motor is clean, no smoke or odd smelling exhaust, plugs are good (slight white/brown residue on plug),
she will lose a quart on a 500 mile trip; only place that I see oil is where the transmission mates to the engine it is wet from oil; and on the plugthreads (the tip/ anode is dry)
I park in the same place and there is no oil on the driveway,
So, I'm asking you guys any ideas?
thanks
jon
Old 10-19-2009, 10:49 AM
totally a bro
Staff
vital22re's Avatar
check replace your pcv valve.
Old 10-19-2009, 11:58 AM
abecedarian's Avatar
^ +1
Old 10-19-2009, 12:14 PM
Kiroshu's Avatar
Yea is there oil in the intake or Throttle body? If so your PCV valve may have had it and be time for a new one.... the oil coming down on the back of the engine near the tranny is prolly running down from your valve covers...... What you should do it replace the pcv valve, the intake gaskets, and valve cover gaskets and go ahead and giver her a tune-up while ur at it.... She may on the other had just have worn pistion rings and burn oil at high rpms....
Old 10-19-2009, 12:26 PM
Another thing to consider is what weight oil are you using? might be a bit thin for those highway drives and is, like Kiroshu suggested, getting past the rings.
Old 10-19-2009, 12:29 PM
Team420's Avatar
jon
Rear main seal? Otherwise... yeah....prolly the valve covers leaking down back.
Old 10-19-2009, 01:43 PM
jonmorgan's Avatar
She's going to an independant toy shop for further tech expertize (ie wife will not tolerate valve cover job in the garage); but, it's either the rear main seal and/ or valve covers which would replace the pcv when done.
I'm not getting any oil in the throttle body, and I'm running castrol 10-30 with lucas oil additive; either way thanks for the help
If its the rear main, not bad as this is the original clutch
zieg9479
02-08-2015 02:01 AM
Strider7
3.4 Swaps
52
06-24-2014 03:43 PM
NCRebel
04-29-2011 10:23 AM
Team420
10-07-2009 05:29 AM
Snipes4ever
08-22-2006 03:46 PM
Quick Reply: oil loss on 95 v6 p/u
