obd codes
Old 05-26-2009, 06:07 PM
Bill 23's Avatar
obd codes
I just replaced a warped head and got all back together no leakes etc. Decided to run codes and came up with 3!! 12, 24, and 31 Where should I start? My manual says 12=RPM signal, 24= intake air temp sensor, 31= air flow meter or short between Vc and E2. Are these 3 related? Not sure if I am posting this in the right place.
Tks Bill
Old 05-26-2009, 06:57 PM
abecedarian's Avatar
24 and 31 suggest the VAFM is not plugged in or some other issue with the wiring.
Check everything around / on top of the air filter.
12 is no NE signal input to the ECU within 2 seconds of starting to crank the engine.
Check the wiring around the ignition coil and make sure all the plugs are clean and securely connected.
BTW- what is the year / engine?
Old 05-26-2009, 09:53 PM
Bill 23's Avatar
that did it , all seems well again!!
thanks very much
Bill
Old 05-27-2009, 01:45 AM
you're welcome.
Also, to clear the codes, you can disconnect the battery for a minute or so to reset the ECU. If the problems are fixed, the codes won't come back.
Old 05-27-2009, 07:09 AM
Bill 23's Avatar
If I have no flashing check engine light, then there are no current diagnosed code problems? and if I access the diagnostic system the codes that appear are previous issues and stored codes?
Old 05-27-2009, 09:44 AM
If you don't clear the code(s), most of them will still be stored even if the the problem is repaired so you have to clear them as I described above. You'll know there are no codes stored if you're in the diagnostics mode and the check engine light flashes a steady on-off pattern.
moparbay
10-06-2015 09:24 AM
bradahman
10-01-2015 09:24 AM
charlie_fong
09-27-2015 10:06 PM
Odin
09-26-2015 06:56 PM
Draven023
09-26-2015 12:41 PM
Quick Reply: obd codes
