O/d switch
O/d switch
Got a 95 4Runner, It had three main shorts..power windows..I fixed..A/C..I fixed..O/D switch has 0.36 volts coming to it. I replaced the push button switch same results? I'm STUMPED
What Sayeth the Good Book? http://www.ncttora.com/fsm/1990-1995...2/troubles.pdf (page 30)
Why did you think the switch was the problem? You should get about 12v (through the indicator light) at one of the switch terminals, ground at the other. If you connect the terminals together the O/D off light should illuminate.
If it doesn't, you've either got a burned-out bulb or a wiring problem. You're probably going to have to pull the panel to check the bulb; when you do that check for continuity back to the switch.
I bought this at a DEA drug seizure auction, they just took the whole inside apart (with-out disconnecting the battery) The windows were shorted out along with the a/c I found the shorts in those. Bulb is good behind cluster... NICE!!!, on the website with the DIAGRAMS!!
kawazx636
10-06-2021 03:03 PM
PNW94Runner
09-29-2015 02:55 PM
charlie_fong
09-27-2015 10:06 PM
runnermedic
13
09-21-2015 05:20 PM
