Not Cranking
Old 01-11-2012, 12:29 AM
Pitbull90's Avatar
Question Not Cranking
Engine not cranking when cold. Ive checked the battery and starter. Both were good. Replaced the starter because i thought maybe it was just weak.
I have a 1990 toyta with a 3vze in it.
Whats the next thing to take apart/check?
-Thanks
Old 01-11-2012, 03:40 AM
skypilot's Avatar
Ignition switch.
Old 01-11-2012, 07:26 AM
Marc's Avatar
When you say "not cranking" go you mean that the engine won't turn over (spin) when you try and start it or won't start?
Old 01-11-2012, 08:17 AM
93toyrunner2's Avatar
How did you check the battery? Did you do a load test on it when it was cold? I would think with your location, and the temp there, that the battery is unable to hold a load when it is cold. Just because the battery shows 12+ volts on a meter doesn't mean that it has the cold cranking amps needed to turn over an engine.
Old 01-11-2012, 01:04 PM
Pitbull90's Avatar
@Mark Yeah it doesn't spin.
@93 toy runner 2 so get a volt meter out while its trying to crank?
Old 01-11-2012, 01:08 PM
abecedarian's Avatar
Not cranking when cold?
It cranks when warm?
Around here, anything less than 50F is cold.
Around here, anything more than 70F is warm.
Old 01-11-2012, 01:09 PM
Pitbull90's Avatar
When cold not at all. After roll starting it and getting it running for a while it will crank really slow but still not turn over.
Old 01-11-2012, 01:11 PM
Check grounds from the battery to the engine block.
Old 01-11-2012, 01:12 PM
Like mentioned above, how'd you check the battery?
Old 01-11-2012, 01:16 PM
Pitbull90's Avatar
My auto store checked it with a voltmeter and it tested 12V and 100% charged. They didn't test while cranking though.
Yeah the grounds are connected to the block and i just replaced the terminals and wires off the battery.
Old 01-11-2012, 01:40 PM
Marc's Avatar
12 volts is not enough for a good battery.
They have to put a load on it to test it properly.
Old 01-11-2012, 01:55 PM
Proper testing a battery is putting a load on it (carbon pile) and seeing how long it will supply "volts". I.e.: supplies 300A for (X) minutes before volts fall below 12.
Old 01-11-2012, 01:57 PM
Pitbull90's Avatar
okay ill get them to retest it while cranking thanks! get back to you later on what happens
Old 01-11-2012, 01:58 PM
Here's another thing to check:
If you jump a wire from the battery + to the starter little wire, will the starter crank the engine?
Old 01-11-2012, 02:42 PM
They don't need to check it while cranking. Tell them to get out the tester that can do a load test. I have one from snap on that reads the battery voltage, and you can push a switch on this tester to do a load test. While load testing it, you can see the condition of the battery on the meter.
Old 01-13-2012, 02:55 PM
Pitbull90's Avatar
@abecedarian yeah they tried that it didnt work.
@Yes thats what they did. I watched them and it tested over the cold cranking thing post on the battery.
It's not the battery, starter, connections, or fuses... Next?
JonG85
01-18-2023 04:31 PM
83yotastockR
11
11-10-2015 06:54 AM
puddlepirate
09-29-2015 08:02 PM
Shagool22
09-28-2015 07:53 PM
gentry
09-28-2015 06:16 AM
Quick Reply: Not Cranking
