New yota old engine
New yota old engine
so i jsut got an 88 ex-cab 22re 4x4 and it has a knocking rod and it needs a rebuild or does any one know an easyer way to fix that and if it does need a rebuild best place to get a kit for it, i looked into engrbldr and for the kit anda cam it was like 260$ let me know what you think
Engbldr makes some awesome stuff. I ordered a front end kit from them and was very happy. I've heard nothing but good things about them.
First you need to determine what is actually wrong with the engine. Don't assume that a rod has a messed up bearing. It could be wrist pin noise, several rods, or any combination therein. Take the engine out, and apart, and start doing some investigating.
If the rods are toast, you likely have hammered the crank. This will require either a new crank, or a crank turn and over size bearings. It all depends on what it looks like when you get it apart. Again, take it all out and apart, THEN order parts.
Regency
20
01-03-2020 07:43 PM
Seattle_Sign_Guy
07-12-2015 12:38 PM
