new shocks??
Old 08-16-2008, 10:55 AM
Jackal's Avatar
new shocks??
if i get 1.5" bj spacers an 2 inch coil spacers or coils in rear do i need new shocks? i just bought some new pro comps last year and i had to compress them a ton to get them in.
Old 08-16-2008, 11:04 AM
Matt16's Avatar
Yes, Procomps are too short for the front.
Jay351's Avatar
You're supposed to have to compress the shocks to get them in at ride height. Otherwise you would have no droop travel. Some of the procomp shocks are spec'd for 0-1" of lift or so. Did you happen to get those?
Old 08-16-2008, 11:14 AM
Jackal's Avatar
i dunno, i bought them at 4wheelparts. and they asked if i had a lift, i said 3 inch body. but i think they must have been the 1 inch lift ones. because i had to compress them at leaste 4 inches just to them the SOBs in there.
when i removed the old ones they didnt extend at all when they were out.
btw, i dont wheel my vehicle at all, so is it really necessery to get the longer shocks?
Old 08-16-2008, 11:21 AM
Jay351's Avatar
Well, I suppose if your runner just stays on the street you dont need the travel. So no. But it would be best if you got the correct shocks.
Old 08-16-2008, 11:29 AM
Jackal's Avatar
yeah i was just wondering if it was okay to leave it like that until i had the money for the shocks.
what would happen if i had short shocks and went off road?
Old 08-16-2008, 11:44 AM
Jay351's Avatar
It would just limit your flex. A too short shock will not damage anything, a shock thats too long will.
Old 08-16-2008, 01:16 PM
Jackal's Avatar
mmk as long as it doesnt ruin anything lol
Old 08-16-2008, 01:53 PM
abecedarian's Avatar
you should be okay with your shocks until you can afford new ones.
even though you're getting lift from the spacers, the lower arm isn't mounted to the frame any lower and where the shock mounts on the lower arm is only going to travel maybe 1/2" or so lower than without the bj spacers.
you can check it when you get the spacers on by jacking up the truck with your shocks on and seeing if the upper arm contacts the droop bump stop- if so, you're okay.
ladybugRC
458
08-21-2020 10:41 AM
ZGjethro
06-07-2017 11:04 PM
dirk89
10-01-2015 05:15 PM
ktm192k
10-01-2015 08:47 AM
hiluxinargentina
09-30-2015 05:51 PM
Quick Reply: new shocks??
