New powers testing pump & idle up valve
Old 12-05-2012, 06:16 PM
herecomesabird's Avatar
power steering pump, idle up valve. burning atf
Have the issue where I'm getting power steering fluid into my exhaust , causing crazy smoke. I need to find a new pump, and idle up valve. I usually buy from ebay but can't find them. Could someone please post a link? and maybe a thread showing the replacement? thanks
Old 12-06-2012, 05:29 AM
TNRabbit's Avatar
Cap off the vacuum lines & take the idle up valve off the pump & replace with a bolt. I did this years ago with ZERO affect in daily use.
Old 12-06-2012, 08:10 AM
ive heard about this. probably going to do that. was your truck smoking badly?
Old 12-06-2012, 02:22 PM
do you have a picture of what yours looks like? what did you use to plug the lines?
Old 12-06-2012, 03:53 PM
took the lines off while t was running...didnt see any atf in them. bone dry actually...i just finished rebuilding my top. correctly. so i know its not valve seals, or a headgasket. ill do a compression check later to check the rings. what about the pcv valve? ive heard that can get clogged and cause smoke. please point me in the right direction, because im losing my mind
Old 12-06-2012, 03:54 PM
also, not that i dont have a cat. idk if that makes a difference.
Charecter1
11-06-2023 10:08 AM
bigjstang
08-25-2021 12:41 AM
06-01-2021 01:51 PM
TURBOrunnerNM
07-22-2015 11:01 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: New powers testing pump & idle up valve
