New cam time - what will I need?
Old 04-02-2009, 04:25 PM
ARSmay's Avatar
This is for my 3.0 v6 1991 Runner - Lifters? Gaskets? Pitfalls and precautions? I'm going to try and get a used cam, since this is going to be mostly a band-aid for a motor with over 200k miles...I imagine a long block is in my future anyway.
I'm just wondering what all I'll need to get ordered before I get started so I've got everything to finish.
Thanks everyone for all your help so far.
Old 04-02-2009, 05:11 PM
abecedarian's Avatar
Maybe you've said it elsewhere, but what makes you think you need (a) cam(s)?
Old 04-03-2009, 04:19 AM
ARSmay's Avatar
Because when the distributor seized, it shredded the teeth from the cam gear that drives it. No. I'm not looking to monkey with something for a performance mod, I just need to fix my truck.
Old 04-03-2009, 06:22 PM
Okay... well the lifters themselves should be fine as should most everything else. You will need to get the valves set though and that means you'd have to put it in and then measure your clearances and procure the proper shims to replace the ones you have.
bigjstang
08-25-2021 12:41 AM
Eggslinger
06-08-2019 03:32 PM
09-04-2015 09:27 AM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: New cam time - what will I need?
