name that part???
Old 06-28-2012, 10:56 PM
Marc A's Avatar
name that part???
So today i was under my 93 4runner v6 and noticed on the drivers side of the block right behind the oil filter there is a round thing bolted to the block with a hose going to the front of the block..
any idea what it is?
Old 06-28-2012, 10:57 PM
INFINITY's Avatar
oil pump
Old 06-28-2012, 11:18 PM
Marc A's Avatar
the oil pump is external with only 1 bolt holding it to the block?
Old 06-29-2012, 06:05 AM
fdp101452's Avatar
oil cooler
Old 06-29-2012, 06:14 AM
92 TOY's Avatar
oil cooler...
Old 06-29-2012, 06:35 AM
Outsane's Avatar
I wonder if I can put one of those on a 22re...
Old 06-29-2012, 06:46 AM
wii_tarded's Avatar
Dunno, I know the 3.4 has it (dunno if same part number :shrug: ) but it works by circulating coolant around the oil. I know that not all 3.0 came with it and you can add it on.
Old 06-29-2012, 12:26 PM
Marc A's Avatar
so does it require any maintance or cleaning or anything?
Old 06-29-2012, 01:02 PM
myyota's Avatar
You probably could. When I used to go to pic n pull a lot I noticed that some toyota celicas with a 22RE actually had oil coolers on them. I should have pulled one and bought it, but I never did.
Old 06-29-2012, 06:30 PM
Punchy's Avatar
The oil cooler does not need maint.
Make sure the hoses going to it are in good shape, Total PITA if you have to fix one of those on a hot engine out in the middle of nowhere.
05-20-2016 10:27 AM
88sasturbotoy
08-11-2015 01:56 AM
Fundy Rider
07-16-2015 01:35 AM
akaphilly
07-09-2015 02:34 PM
Quick Reply: name that part???
