Mysterious 3ZVE coolant leek
Old 06-06-2012, 04:21 PM
splangeland's Avatar
I just replaced the pcv valve along with the grommet, valve cover gaskets, intake and throttle body gaskets on my '94 Runner with the 3.0. I now am leaking coolant like a siv. When I drive somewhere and park it I can sit and watch the coolant drip right out of it. It is dripping out of the back of the engine somewhere but I don't see any hoses I accidently didn't reconnect. Does anybody have any idea why. I read somewhere on here something about the cap on the overflow tank being on backwards, which way is the lip supposed to face, to the rear of the car or the front? Thanks
Old 06-06-2012, 04:39 PM
MudHippy's Avatar
There's more hoses full of coolant back there than you can shake a stick at...take your pick!
And...with the lip towards the front.
Old 06-06-2012, 04:47 PM
totally a bro
Staff
vital22re's Avatar
Did you use pliers to remove the hoses for the throttle body? sometimes when people do this they damage the hose with the teeth on the pliers. Are all the clamps in place and secure?
Old 06-06-2012, 05:05 PM
rworegon's Avatar
Get a mechanics mirror and take a close look.
Old 06-06-2012, 05:23 PM
When I replaced said items I simply undid the bolts and only pulled a few hoses from the drivers side and simply flipped the whole mess outta the way with only disconnecting like 3 hoses I think. (saw it on youtube)
Old 06-10-2012, 04:19 PM
So no other ideas? Drove to work this morning and when I got there I had coolant everywhere! I filled back up with water since that was all I had and there was only a small amount leaking when I got home. I need to figure this out pronto but Im about to take it into a shop and let them deal with it.
Old 06-10-2012, 04:32 PM
Kiroshu's Avatar
Throttle body cooling hoses... even if you didn't disconnect them and you said you just "flipped" the whole shi-bang out of the way you may have cause the very old and brittle throttle body hoses to crack and or split.... the throttle body cooling hoses will leak down into the intake manifold and run down the valley of the block and out of the back of the engine.
Old 06-10-2012, 04:35 PM
rworegon's Avatar
Coolant everywhere? 100% of the engine bay covered in coolant? It really should not be terribly hard to find the leak.
Fill up the radiator, take it for a drive to get it up to temp, and then pull over see what you see under there. Leaving the engine running may show the source as it will be under pressure.
Also, a cooling system pressure check will show where its leaking.
Old 06-11-2012, 03:43 AM
iselloil's Avatar
The coolant hose under the heat control valve,or bypass hose on the passenger side.Pull the plenium and repalce all the hoses at the same time. You'll never do it on the side of the road,whith a blistering hot engine.
Old 06-11-2012, 04:42 AM
93toyrunner2's Avatar
Most likely one of these 3 hoses, but a coolant system pressure test will help you spot it:
Old 06-19-2012, 03:44 PM
motocrossaddict223's Avatar
you know where all those sensors are in the back of the motor? check that manifold, when i replaced my ks i cracked it. it is a bitch. I got one from a 2nd gen and it had one extra sensor but it worked. mine cracked underneath.
ladybugRC
458
08-21-2020 10:41 AM
LittleUgly
15
01-02-2020 01:30 PM
wberry85
05-17-2016 05:45 PM
alexcarey
10-14-2015 06:05 PM
kcaudill
10-10-2015 02:39 PM
Quick Reply: Mysterious 3ZVE coolant leek
