Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
My Very Used Runner
starting a build tread so to speak cuase i keep gettting asked what i've done to my runner...so sit back and enjoy
it's a 89 4runner 3.0L, auto, power everthing,working A/C here it is stock when i brought it home ![]() it needed some work...needless to say about a year later when i started to wheel it ![]() i added a AAL to the rear, cranked the t-bars and added a 1" BL, also did small things like diff breathers intake mods and replaced some body panles soon after TG sliders and a MC rear bumper...ignore that sad excuse of a front bumper/light bar ![]()
__________________
89 4runner 3.0L, 5spd swaped like what ya see...check my build http://www.yotatech.com/f116/my-very...runner-143762/ Don't Follow me, you won't make it "Wheeling the piss out of it" AND "DD"ing it since 2005 |
| Sponsored Links |
#2 (permalink) |
can't find any pics but about 6-9 months after the rear bunper and sliders i did the chevy 63" springs in the rear, also relocated my shocks, did a u-bolt flip and added a lockrite. as for the front i cranked the t-bars some more
finished up most of the body work and painted it 1 solid colorput on the new shoes...33x12.5 BFG MTs ![]() ![]()
__________________
89 4runner 3.0L, 5spd swaped like what ya see...check my build http://www.yotatech.com/f116/my-very...runner-143762/ Don't Follow me, you won't make it "Wheeling the piss out of it" AND "DD"ing it since 2005 Last edited by LTrunner : 04-27-2008 at 04:37 AM. |
#3 (permalink) |
added some other things like a soft top and a hi-lift mount...also removed the carpet from the rear of the truck and hreculined the bed
![]() ![]() which brings up to now...the weekend after this pics was taken to cut out an inch and 3/4s out of the rear wheel wells,it was a tight fit as you can see, but not anymore...i also removed the rest of the carpet from the truck and i'm workin on herculining it now. i'm also gathering parts for my 5spd swap...got my trans yesterday, i have everything but the gear driven t-case,and adpater im putting in a v6 trans with a 4.7 case on it, i got TG's dual case x-member so if i chose to go that route later, it will work with a single case ![]()
__________________
89 4runner 3.0L, 5spd swaped like what ya see...check my build http://www.yotatech.com/f116/my-very...runner-143762/ Don't Follow me, you won't make it "Wheeling the piss out of it" AND "DD"ing it since 2005 Last edited by LTrunner : 04-27-2008 at 04:47 AM. |
#4 (permalink) |
that's where i'm at now, shooting to put the 5spd in sometime next month...right now i'm looking to make some half doors with custome soft uppers(like a jeep so to speak)
__________________
#5 (permalink) |
Looks nice..I like the soft top!
__________________
2006 Tacoma SR5 - Stock for now 2000 4Runner Limited 16x8 Pro Comp Steelies wrapped in 285/75R16 Pro Comp M/T'S~RB 2" Body Lift~E-Locked~Rear Locker Mod~Rear Diff Extended~Surco Safari Rack~ Optima Yellow Top~ Trail Gear Sliders~6 100W Hella 500's~Tacoma Whip Mod~ Deckplate Mod w/ True Flow~ISR Mod~~Autometer Volt and Oil Press gauges~Satoshi Grille~Redline Hood Lift~Hayden 1678 Aux Cooler |
#6 (permalink) |
looks like it has come along way, i think a smell a sas in the future tho
__________________
1997 Toyota 4x4 SR5 4runner 3.4 auto Toytec 3 inch coil spring Lift Trail Gear Rock Sliders Maxxis Bighorn M/T's Amp Custom Rims Cobra CB, 5ft Firestik KC Daylighters http://www.cardomain.com/ride/3008195 Near Future List Bumpers Lockers 1st Gen Roll Bar Winning the Lottery? |
#7 (permalink) | |
Quote:
__________________
#8 (permalink) |
Lookin Good.
__________________
1988 4 Runner w/225,XXX miles, 3.slow V6. A/T. 4.10s?-(G292 code) and power everything else that still works, except someone broke off my electric antenna. 1.25" BL. Used Marlin Crawler Rear Bumper, 33 x 12.50 x 15 on Steel Chromies w 3.5" BS. Has new shocks, leafs. Soon; ZUK brackets & coils, rear shock brackets & flip kit, r. lockrite, 529's, sliders, 5 speed swap |
#9 (permalink) | |
Every time I see something like this all I can think is "I wish I had more time and money".
Nice rig.!!!
__________________
1986 SR5 pickup. Tread Wright 31/10.50 15's. 4.56 thirds, an Aussie in the @$$, low profile bumpstops and Marlin Crawlers front and rear. Quote:
#10 (permalink) |
so far without the 5spd swap i've spent about $1,000 on off road mods and about $1,000 on matance/upgrades...but it was over the span off 2 years
__________________
#11 (permalink) |
ok so today i fix up the trans...i got the trans for $100 it came with the t-case already off of the trans,it was missing the shifter lever, and missing a set of bolts...anyways the previous person unbolted the transfer adpater form the trans and it wouldn't shift that good so i fixed that...
first i had to totaly remove the transfer adapter ![]() when i removed it i found that the shifter forks weren't all alinged so i lined them up and put some new RTV gasket on it... ![]() the last thing was to get the shift rail into the shift forks without misaligning them, and centering it at the same time...i did all that and man it was a pian. i put the pieces back together and toruqed it down...it works great now...sorry no finished porduct pic![]()
__________________
#12 (permalink) |
all i have left to get is the t-case, and the trans to gear driven case adapter...hopefuly i'm getting a t-case from a guy that already has the 23 spline input in it for $150
__________________
#13 (permalink) |
alright the adpater i need is sale till the end of the month
http://www.inchwormgear.com/store/pr...products_id=34
__________________
#14 (permalink) |
i found a pic of how my truck looks after i trimed one and 3/4 inches out of te rear wheel wells
i think it looks alot better now that the rear wheel well hieght macthes the front ![]()
__________________
#15 (permalink) |
got my t-case today...cost me $150 and the guy threw in the 23spline input..
here it is... ![]() the 23 spline input.. ![]() all apart... ![]() all put back together with the shifter and mount ![]() next firday i'll be ordering the marlin adapter, and going to toyota to pick up a few things...then the swap will bethe following weekend...I CAN"T WAIT!!!! ![]()
__________________
#16 (permalink) |
so this past weekend was fun here's a hint as to what i did
__________________
#17 (permalink) |
thats whats up
you excited ?
__________________
{1991 4x4 p/u 22re--elbow mod} {Wrecked 86 one ton.} Both under construction :) Dad- 1999 4runner base 2x4, 2.7, 5speed, 49k, cherry. |
#18 (permalink) |
you bet...the truck is re-born, has alot more power, response, and toruqe than the sliping auto did.and i love 4lo with this t-case, it's lower than my auto was
i'll get some more pics later...but i had to change the rear d-shaft for a longer one(out of a 5spd truck). and i gained about 2inches belly clearance with the new x-member ![]()
__________________
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 87 runner and 85 runner parting out | insane04 | Misc Stuff (Vehicle Related) | 6 | 05-28-2008 09:15 PM |
| just got a 93 runner | damage_priest | 86-95 Trucks & 4Runners | 1 | 04-20-2007 04:26 PM |
| Solid Axle Runner and IFS Runner Decisions | GreeneHoosier | 95.5-2004 Tacomas & 96-2002 4Runners | 15 | 11-18-2005 08:14 AM |
| Towing 86 runner with 90+ runner?? | wimpywade94 | Offroad Tech | 4 | 08-21-2005 02:44 PM |
| 92-95 runner bumper work on 91 runner? | 914runner | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 05-25-2004 10:17 PM |
