Motor wont spin when rod bolts are torqued
#61
The motor runs well. I have 115 miles on it. I do not suggest the 261C cam to anyone that is planning on high revvs. I rev these motors out and wanted to go with the 268 cam, or another brand, but Tod insisted that the 261 would be better. It feels like the 261 falls flat up top. The motor feels like a mid range motor, not a high RPM like I was planning. Everything is tight and sound, no vibrations, and it started up in the first 10 seconds of cranking (after priming, of course). I wish I opted for forged piston, for this motor will be seeing boost. If it blows up or cracks a piston, I can only kick myself.
How does the 261* cam compare rpm-wise to stock? What size exhaust are you running?
#63
I am running all stock exhaust until after the cat, which it opens to a 2 1/2" piping with a 2 1/2" Magnaflow muffler.
#67
I'm not doggin the cam itself, nor Tod and Ted. I just don't like the cam for what I'm doing, it's not the right cam. I do not want to spend more money on another.
#74
It's horrible! I'm 6'6, tall to say the least, and I cant count how many times my head has hit the roof. I need to do something about it.
But with the 4" drop, the thing handles like it's on rails. It'll keep up with that Starion handling wise. Although, any type of rut or road bumps in the turn, and I'm toast. The back end just bounces around.
kgcwb44
01-29-2023 10:02 AM
09-04-2015 09:27 AM
pyramid
07-30-2015 10:05 AM
