motor problems Help
Old Dec 12, 2007 | 12:35 PM
4runnerguy's Avatar
motor problems Help
i have a problem that when the motor is cold it runs fine. but when it gets worm it sucks like crap in all gears i put it in first it just bogs after i pass 3000 rpm its all good does this have to do with timing its been like it this for a week i dont know what to do
Old Dec 12, 2007 | 12:40 PM
Froggy93's Avatar
What year and engine size do you have? Also, any check engine light?
Old Dec 12, 2007 | 12:41 PM
4runnerguy's Avatar
1991 toyota 4runner v6 3.0 no light has flashed at all
Old Dec 12, 2007 | 12:47 PM
Froggy93's Avatar
Sounds like maybe a stuck EGR valve or sticking cold start injector. does it want to stall when sitting at an idle when you are stopped?
Old Dec 12, 2007 | 12:51 PM
4runnerguy's Avatar
nope but there is another thing that happends its just once and a wille rpm drops almost to zero for a split second even if im driving or standing still
Old Dec 12, 2007 | 12:53 PM
4runnerguy's Avatar
can u fix the egr valve without buying another one
Old Dec 12, 2007 | 01:01 PM
Froggy93's Avatar
yeah sounds mainly like your EGR valave is sticking. It is bolted to the pass side of the intake manifold. i.e. the side with out the intake tube and throttle body. Try tapping on it with a small hammer or other hard object. This may release the valve and it will hopefully close up completely. It sounds like you are running righ. The EGR feeds unburnt fuel vapors and exhaust gasses back into the intake. If it is stuck open, it is feeding the excess unburnt fuel vapors causing the engine to run rich. It will run like crap at lower RPM's and smooth out at higher RPM's. i.e. how your truck smooths out above 3K. Try that out.
Old Dec 12, 2007 | 01:02 PM
Froggy93's Avatar
It will eventually need replaced if it is sticking.
Old Dec 12, 2007 | 01:15 PM
4runnerguy's Avatar
its not tickin
Old Dec 12, 2007 | 01:48 PM
4runnerguy's Avatar
i found the problem one of the spark plug wires had a cut on the so the spark was jumpin to the side of the motor
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
msane99
Jul 17, 2015 10:13 AM
AaronM
Jul 8, 2015 07:15 PM
karbin
Jul 5, 2015 11:37 PM
