Milky white oil cap -.-
Old 11-12-2010, 01:20 PM
Yotamunky's Avatar
So topic basicly sais most of it. I have a 92 22re with 435xxx kms, I checked the radiator and it defenitly has some oil in it, this must have just started to leak because i check my oil and coolant regularly. Would anyone be able to give me a rough estimate on how long i have until this starts doing some serious damage? or my engine simply stops running?
thx
Old 11-12-2010, 01:28 PM
bobby_duce's Avatar
doesnt that mean your getting coolant in your oil?
Old 11-12-2010, 01:31 PM
Junkers88's Avatar
Stop driving it. Really.
Old 11-12-2010, 02:14 PM
rattlewagon's Avatar
Yeah. Thas moisture in the oil. Get the oil thats in there out stat.
Old 11-12-2010, 02:18 PM
Teuf's Avatar
Get out your FSM, you will be doing a head gasket my friend. Good Luck.
Old 11-12-2010, 02:20 PM
Yotamunky's Avatar
alright thx for the input. Any ideas what this mite be from my minimal knowledge im thinking blown headgasket?... this is my comute to work vehicle so i cant exactly just stop driving it. gonna need to start working on a solution
Old 11-12-2010, 02:24 PM
yotarob2005's Avatar
Timing chain guides wear out and cut the aluminum timing cover, mixing the oil & coolant on 22re's pretty often.
Old 11-12-2010, 02:45 PM
Yotamunky's Avatar
alright guys thx for the input. time to start getting dirty and figure out whats up for real
Old 11-12-2010, 03:05 PM
If you plan on DDing it, your on borrowed time. Its leaking now, but could go at any time.
Old 11-12-2010, 09:39 PM
InvaderTrax's Avatar
x2 I had an Integra that had milky oil and it spun a bearing the next day. Stop driving and start saving for parts
Old 11-12-2010, 09:55 PM
drmix's Avatar
You should get it taken care of soon before you do more damage and have to replace the whole motor
Old 11-13-2010, 01:21 AM
toyotabull's Avatar
Head gasket set, timing chain kit and timing cover. I would change all that atleast. Might as well if your pulling the head to replace the gasket. Read a manual before you start pulling bolts, plus bag and tag everything you take off. Take pics of every bolt you pull. Wish someone would have told me these things the first time I tore an engine apart.
Old 11-13-2010, 06:33 AM
motocaveman's Avatar
I've got a complete 4 piece front end kit from ENGNBLDR that I purchased about a month ago. Bought it thinking my timing chain and guides went kaput and came to find out it was in good shape. If you need that kit PM me and we can work something out..........
Old 11-14-2010, 05:39 AM
87 'runner boosted's Avatar
kinda new to these things...work on semi engines mostly and wasnt sure...but on big engines, oil coolers are usually the culprit on those engines when there is oil in the coolant and not coolant in the oil....doubt this is helpful at all cuz i dont think these engins have oil coolers, but Its a try...
Old 11-14-2010, 10:12 AM
Yotamunky's Avatar
Yes when i pull the disptick out it is just pure oil. and then a bit of white crap in the oilcap.
If i look into the radiator u can see oil swimming in the coolant.
I live in a townhouse complex so i dont really have any room to do a lot of work on it myself :\ and was really just thinkin about getting a new engine dropped in.
But if i pull the head cover off and look at were the timing chain is should i be able to see if its worn out and thrashed? or do i have to pull out hte camshaft and valves and whatnot?
Sry for all the questions, really newb wrencher
Old 11-14-2010, 12:16 PM
Junkers88's Avatar
Might not be a bad idea to update your profile to reflect where you live. I'd be good money that there is someone close that can stop by and give you a hand looking at it. You might even luck out and find a wrenching buddy that will help you fix it.
Old 11-14-2010, 03:09 PM
Yotamunky's Avatar
alright well i guess ill go buy a compression test guage tommorow then and do that. What is a leak down test?
also if my headgasket is blown, or the timing chain guides are worn out, would i notice any sounds or my engine acting weird when i actually drive it
Since i noticed the white stuff in the cap i have driven it a bit and it still seems to drive the same as always.
Old 11-15-2010, 04:51 AM
another thing we experience here in the shop a lot of times is that if the coolant leaking into oil isnt very bad yet, a lot of times the coolant evaporates once it hits the oil due to high oil temps....once again, i work on semis mostly, so dont take my word for gold, but that would explain why there is a white residue on the cap and not showing any in the oil...could be moisture evaporating upwards.
Old 11-15-2010, 04:12 PM
Yotamunky's Avatar
Alright thx for all the helpfull info. I checked the coolant again today and its defenitly draining to somewhere because its way lower than yesterday
The other thing i noticed, i started the engine and let it warm up, and when i was sitting inside i could liquids moving around. sounded like it was coming from behind the dash or something. was a very weird sound
Old 11-15-2010, 04:22 PM
peow130's Avatar
ALSO...
Since your engine is SOOOOO high mileage, we can assume that the timing chain guides are toast, and the chain wore a hole through the cover..
I'd be willing to bet that that's the problem.
Was the sound a slight tapping that didn't change with RPM, and happened at random?
Quick Reply: Milky white oil cap -.-
