mercury villager electric fan swap
Old 10-02-2009, 07:00 AM
runnermedic's Avatar
Hi !!!!
during my research i discovered a new way to swap the clutch fan for an electric one.the donor is a mercury villager from 1993 to 1995,this fan is a 2 speed with big blades so it will work,anthe best part is that the shroud is bigger than the taurus fan so it will cover the bottom of the radiator.there are plenty of them in ebay at a good price even new ones.some minor modifications are required to fit but it will work perfectly.
so here is the picture.make some research and let me know your progress.
if anyone need the relays write up let me know.
Attached Thumbnails mercury villager electric fan swap-35929387.jpg   mercury villager electric fan swap-radiator_cooling_fan.jpg
Old 10-06-2009, 07:15 PM
mercury efam dims
mercury villager fan
Attached Thumbnails mercury villager electric fan swap-efan-mercury-villager.png
Old 10-06-2009, 07:56 PM
olharleyman's Avatar
Hey you can shot me them diagrams I am going to start looking for one soon
Old 10-06-2009, 08:26 PM
muddpigg's Avatar
Thanks runner, you going to homebrew the control or buy one?
Old 10-06-2009, 08:54 PM
Grunnen's Avatar
also interested if you can post them
Old 10-07-2009, 05:16 AM
wiring diagram
Attached Thumbnails mercury villager electric fan swap-wiring-fan-2-speed.png
Old 10-07-2009, 06:03 AM
Stuwy123's Avatar
You wouldn't happen to have the wiring diagram for the stereo in that mercury villager would you?
I've got a little project involving a lot of speakers from the Nissan Quest (Same vehicle, built in Japan, rebadged).
Old 10-07-2009, 06:07 AM
the controller i use is a hayden imperial thermostatic controller whit adjustable temp dial.when using this controller make sure the probe is mounted behind the upper water inlet,when testing the switch select first at 1/4 turn clockwise then make the adjustment until your desire fan kick point.cover the part that will pass the radiator fins to prevent false readings it can be cober with a dap of silicone or a rubber plug.
the controller is availabe in advance auto parts
part number . 226203
price $18.69
Attached Thumbnails mercury villager electric fan swap-hayden-imperial-226203.png
Old 10-07-2009, 06:09 AM
buddies post here your pics progress making the fan swap
and your own experiences!!!!
Old 11-02-2009, 02:45 PM
for those looking for the mercury villager fan assembly i have good news!!!!
recently i buy a fan assembly for a buddie of mine and results his was cheaper than mine.
surfing the web i found this great place www.vikingautosalvage.com
for my surprise these people have in stock the fan assembly used ones for $30 bucks and for the new one ,,,,, hope you are sitted !!!!! $39 bucks !!!!! what ? yep $39 bucks for a new mercury villager replacement fan assembly,,,,so i order one for my friend and one for me just in case mines fail. take a look at the web page and you will see these people are the real deal excellent service and top notch sales rep. and yes they also have toyota parts new and used so what are you waiting for get rid of that ugly power sucker clutch fan get an electric fan !!!!!!!
Old 11-02-2009, 06:09 PM
stormin94's Avatar
Hmmm... looks interesting. I might be looking to do that pretty soon.
Old 11-02-2009, 06:34 PM
predator_machine's Avatar
I discovered a way too, I do not know what the fan came from, I suspect an old ford escort. Its real easy, involves some wire, a switch and zip ties. (out of necessity of course). My electric fan is much smaller than the Villager's fan, and it is not needed on the highway at speeds over 55, and keeps the motor cool even on the steepest mountain roads near my house. Just gotta remember to flip that switch.
The following users liked this post:
TuckerTJ (03-07-2019)
Old 11-03-2009, 05:24 AM
make your self a question predator
how a 4banger fan can cool a big v6?
first it has to be 16 inch minimun diameter,did you know how much cfms it makes?
no right!!!!, so stop quesing around,the villager fan pulls at low nearly 1300 to 1500 cfms dependind on the shroud and in high it pulls nearly 2400cfms thats a los of air.this fan was designed for a v6 too the villager is a 3.0 v6 and build heat as our 3vz take in mind not only cool the radiator you need the fan to be plenty of power to disipate that heat from around the engine.the villager fan is similar as the mark a 17 inch fan ,a big shroud and a powerfull motor,,,,, and yes it drwas a lot of amps when kick on but this can be resolved with some good relays. and of course you can get a new one from the site i posted !!!!
Old 11-03-2009, 07:40 AM
muddpigg's Avatar
If you creep and crawler its nice to have the relay wired to a switch for always on, off for water crossings, and auto thermostat. Really the always on is more for the powersteering as it will take a beating and also for crawling on deep snow. But I doubt that is an issue in PR.
Old 11-03-2009, 07:59 AM
runs more I suppose. You know that fan only comes on when the temp goes on above a certain temp. I dont live out in the desert or big city, it does what I need it to do and only complaint I have is having to flip a switch, and that ought to be fixed but I gotta finish my mercede$ project first.
Old 11-03-2009, 08:04 AM
and I said I think an "escort" but really do not know what this fan came off. I do know it is a bit smaller than the fan that came off it.
In case you still dont get it, that was not a preformance mod, this was cause I do not have $8+0 to spare for new fan and clutch.
I live in very steep mountainous terrain, about 2,000 feet above town. The fan keepts it cool, should I take pics of the temp gage?
Old 11-03-2009, 08:32 AM
few simple rules to follow making the efan swap
1.use good relays
2.good cables
3.use a manual thermo switch
4.be secure of having a 16 to 17 inch dual speed fan most of them come from big engines
5.make a manual on off circuit just in case you are deep diving or hill climb a must with auto tranny
6.mantain clean the engine and the cooling system,this is the most important part a dirty cooling system will not work well.
7.check your battery make sure is in good cond and apropiated for your vehicle
8.most of 4runners and pickups with clutch fan came with 70 to 80 amps alternator,so a heavy sound system and efan will draw to much amps hurting the alt.
9.if you still want to have both the efan and a heavy sound system get a gel battery and a camry 3vz -fe alternator it produces 120 to 130 amps the only problem is that you need to modify "bored out" the 3vz alt damper to fit the camry alt shaft.plugs are the same.
following this rules will minimize headaches and the swap will last probably more tahn your truck sooooo happy mudding!!!!!! pals
Old 11-04-2009, 07:49 PM
some pics of the swap
when cutting the right side i forgot to mark the screw holes and made a straight cut,but when cutting first mark them up and you can use the shroud as a bracket with the oem bolts.
Attached Thumbnails mercury villager electric fan swap-1.png   mercury villager electric fan swap-2.png   mercury villager electric fan swap-3.png
Old 11-05-2009, 02:19 PM
aviator's Avatar
good find medic
a lot of us have done the Taurus mod (my fan got tossed before I was able to do the mod) so this gives me another option.
Old 11-05-2009, 07:27 PM
good for you!!! go ahead and enjoy,did you know how a 3vz sounds when reving up?
with the swap you will hear and believe me sounds very nice and peepeeeee,another benefit you are going to have, get rid of that ugly fan clutch noise.
well what more can i say!!!!!!
DEATH TO THE TAURUS FAN SWAP!!!!
RIP TAURUS FAN !!!!!!!
Quick Reply: mercury villager electric fan swap
