manual stick shaking while over 50mph
Old Sep 4, 2008 | 12:21 PM
sincal's Avatar
ok i have a question that i cant for the life of me find the problem out. I have a 90 yota pickup 4x4 22re manual trans on 33's with 4 in suspension lift and 2 in body.
While driving no matter if im in fourth or fifth gear, my stick shakes back and forth pretty bad. The steering wheel does not shake near as much as the stick. It does a little but not bad. I have replaced all tie rod ends as well as put a new steering dampner on and got the truck aligned, still i have this problem. The truck it self does not shack that bad being i have 33's but the stick is out of control. Can someone enlighten me on what i should do next or what the probable cause could be?
edit* by the way i did check the pitman arms as well as the idler arms and they look good. thanks
Old Sep 4, 2008 | 12:40 PM
Team420's Avatar
U-joints maybe, bad tire, bent drive shaft, bent output shaft...could be a bunch of stuff....jack it up, put it in gear, and watch the driveline...see if it is turning smooth, and no wobble.
If you get a clunk when starting off, and decelerating ....you most likely need ujoints.
Old Sep 4, 2008 | 12:52 PM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
i vibrate pretty noticeably between about 50-60 mph. ive chalked it up to one of lifes great mysteries
Old Sep 4, 2008 | 01:32 PM
grant526's Avatar
Motor mounts? Have you considered replacing them?
Old Sep 4, 2008 | 01:51 PM
abecedarian's Avatar
since it's speed related, maybe a tire out of round or out of balance- possibly a rear since the trans is taking the shaking, but i would lean towards the driveshaft being out out of balance or a u-joint taking a dive.
Old Sep 4, 2008 | 02:08 PM
iamsuperbleeder's Avatar
like others are saying, I would say u-joint or drive-shaft, and maybe a bad mount; more than likely a combination of the two
when in first starting off, does the stick try to pull to one side a lot? if it does, that's usually a good indication a mount's shot; the hole motor and trans torques to the side and the stick goes with it.
if you've got a bad u-joint it'll throw the drive-shaft slightly out of balance, wich might just be a vibration normally, but if the mount/mounts are shot, it'll turn that little vibration into a big oscillation... of the drive-train that is...
Old Sep 4, 2008 | 05:46 PM
GoFish's Avatar
I just had this problem and it was the transmission mount. The rubber bushing was basically disintegrated after 24 years.
Old Sep 4, 2008 | 06:02 PM
and that is a prime example why in my post I didn't specify what kind of mount...
a bad motor OR trans mount can cause the same symptom
Old Sep 4, 2008 | 07:44 PM
sincal's Avatar
i should have mentioned i have already changed the motor mout, i have yet to change the trans mount. I might consider that.. is there a test i can do on that mount? And how should i check to see if a U-joint went bad?
Old Sep 4, 2008 | 07:55 PM
the basic test of u-joints is to jack the wheels off the ground then grab the drive shaft and try to turn it- if you can move the drive shaft with your hand and can see 'free play' in the u-joints, the u-joints need replaced. but if you have greaseable u-joints, and haven't greased them in the last 10000 miles, replace them.
Old Sep 4, 2008 | 08:05 PM
sincal's Avatar
i shall give that a try in the a.m thanks
Old Sep 4, 2008 | 08:37 PM
I should've added that the wheels shouldn't move.
Jacking them up just takes the stress of the u-joints caused by binding the gears and such.
Old Sep 4, 2008 | 08:41 PM
sincal's Avatar
alright so just jack up rear end and try to turn the drive line?
Old Sep 7, 2008 | 08:39 AM
grant526's Avatar
Very true. I made the mistake of assuming most people understand the 3rd motor mount is under the rear of the tranny. My bad.
Especially if you have already changed the front motor mounts. I would definitely change the rear as well. It's cheap insurance and shouldn't take much to do.
krimsonone
Sep 13, 2024 09:33 AM
stoneboy91
Apr 5, 2016 05:17 PM
lectric80
Aug 11, 2015 12:02 AM
v_man
Jul 23, 2015 04:01 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
