lsd ifs front diff
Old Sep 3, 2008 | 12:14 AM
imsoho's Avatar
lsd ifs front diff
hi my name is leigh im looking at putting a lsd unit in the front of my 91 surf i have 4.8 ratios in it now and was looking at putting a locker in the front till i heard bout the steering problems going into corners. now to find a lsd ifs front diff carrier is almost impossible only ever seen one??? is it possible to swap a f code carrier from a soarer mz11 model into the front of mine and what troubble will i run into. thanks
Old Sep 3, 2008 | 05:55 AM
tc's Avatar
tc
To help your search, the Soarer is called a Supra in the USA. Supposedly, the LSD will work.
What do you want to accomplish? LSD is great on the road, but you're probably not in 4WD then ... LSD is almost worthless offroad IMHO, as it doesn't work when you really need it (wheel off the ground)
Old Sep 3, 2008 | 08:00 AM
Matt16's Avatar
It may be worthless rockcrawling, but I wonder about mud, snow, sand, loose gravel, dirt etc, stuff where one wheel has a little less traction and ends up spinning.
Old Sep 4, 2008 | 10:48 PM
imsoho's Avatar
an lsd in the front will be much better in the front than the open i already have i dont have a wheel off the ground that often and if i do im prob not expecting to make it up any way. just more for going up wet hills and loosing traction half way up. but when in 4wd still want good steering. this is the only way i can think of doing it without spending lots of money
Old Sep 4, 2008 | 10:59 PM
Matt16's Avatar
Have you got a rear locker. Takes a little skill to drive with one in the rear, but it isn't hard to drive so that it is unnoticeable. I found a huge increase in traction.
I'd like to hear more about front LSDs from non-rockcrawlers, in situations like mud, snow, dirt etc.
Old Sep 5, 2008 | 12:16 AM
Jay351's Avatar
Sounds like a limited slip would work great for you Steering is only an issue with lockers and spools..
Old Sep 5, 2008 | 04:45 AM
bigt's Avatar
toyota lsd are only good for about 50 000k
i have one in the back of my surf with 4.88 never tested to see if it still works at 108000km.
id just bite the bullet and elock or even lockright the rear and be done with it...
me..my surf dont hit any offroad and will drag my welded up runner there is good enough for me!
Old Sep 5, 2008 | 04:54 AM
saitotiktmdog's Avatar
I just put a tru trac lsd in the front of my 1994 pickup. I have a lunchbox locker in the rear. Granted I have not had a lot of time to test it out offroad in all situations but in the little that I have tested it has worked great. Mostly steep hill climbs where traction is key. Seems to work great so far. I don't doubt that a lsd woul be terrible for rock crawling but i dont see many rocks in Indiana. I cant wait to try it out in mud and snow.
Old Sep 5, 2008 | 08:29 AM
Matt16's Avatar
Keep us posted.
Old Sep 5, 2008 | 12:21 PM
InternetRoadkill's Avatar
TruTrac up front is great for mild to moderate off-roading.
Old Sep 6, 2008 | 02:25 PM
Took my truck out for some mild wheeling today. Mostly hill climbing. Seemed to work great. One hill had a pretty good grade to it. Made it up no problem. Both fronts were turning the whole time. Seems great so far. Never really had a wheel off the ground though.
Old Sep 6, 2008 | 06:00 PM
annoyingrob's Avatar
No it's not. A Soarer (JZZ30) is a Lexus SC in North America.
The MZ11 I think was a cressida here.
Old Sep 6, 2008 | 06:15 PM
abecedarian's Avatar
and the cressida hasn't been offered since the mid 80's in the usa.
the cressida name was folded into the 'camry' moniker in the late 80's and disappeared when the camry went full FWD.
Old Sep 6, 2008 | 07:28 PM
tc's Avatar
tc
OK, whatever, but the Supra LSD mod is what you want to search for on here.
Old Sep 7, 2008 | 03:17 PM
Yeah, 82-86 Supra to be specific. They used a 7.5" IRS suspension setup. 79-81 Supras had a 7.5" SRA, but I'm 99% sure the gears are interchangable with the IRS. Not all of the SRA Supras came with an LSD though.
The M motor Cessidas also used the same differential. Changes are, if your Soarer is equipped with a 5M-GE, or a 7M-GE, it's a 7.5".
86.5-92 Supras are an 8" rear-end, and will not work in your IFS. The LSD might work in the back though.
Old Sep 7, 2008 | 04:06 PM
corax's Avatar
here's the thread you want to look at
The *official* 7.5" Supra LSD into a IFS diff thread
when junkyarding, the axle code you want to look for is F**3 (f=7.5" ring gear, last digit 3=lsd) - if you were looking for an LSD for the back of your truck, the axle code would be G**5 (G=8" ring gear, 5=lsd) - on the front, keep all the diff bearing shims. you can mix and match between the supra and 4runner to get proper backlash and it is damn hard finding those shims (neither dealer I called could get them, maybe a machine shop or company such as Yukon can)
a relatively easy swap though, especially if you are keeping the stock gearing, my whole swap cost ~$80 including fluids and the diff from a Pick-A-Part (had it out of the donor in 30minutes)
I pulled one out of a '82 Celica Supra w/ 205k miles on it, on disassembly the clutch packs still had plenty of material left. on reassembly into my truck, with the diff filled, I couldn't hold one tire still while the wife was spinning the other side
Old Sep 7, 2008 | 07:12 PM
Matt16's Avatar
Wives can't exert much torque on the tire. Imagine 400 wifes (!!!) holding the tire in place, and holding the tire in place, as you turn to turn it. That's more like it.
88sasturbotoy
Jan 30, 2026 01:57 PM
jaretstuff
Aug 4, 2015 02:08 PM
Steven.m.paulk
Jul 24, 2015 01:44 PM
scottyg486
Jul 19, 2015 05:34 PM
TokyoD23
Jul 12, 2015 06:01 AM
