Lower Rear Shock Mounts '87 p/u
I have been searching for replacement lower rear shock mount plates for my '87 pickup. It appears Toyota has discontinued this part. Does anyone have ideas on where I can get an aftermarket or replacement? I've scoured the internet but can't find anything. I think the part # is 48040635120. Any help is appreciated. Thanks
Try these guys, I'm sure they'll have it!
http://www.yotayard.com/home.htm
95.5-04 tacoma plates MAY work, as they're very similar in design and have the same sized axle tube.
Just some food for thought.
Or, take the opportunity and do a u-bolt flip kit.
Thanks for all the suggestions. Hadmatt54 I will definitely check Yotayard - thanks a lot. To answer your question wyoming9, mine are rusted so bad I can't pass NYS inspection any longer (I bought the truck from a guy on Cape Cod. Needless to say, it has been exposed to a lot of salt water). If you happen to have any please let me know. Scuba, the U-bolt flip kit is a good idea and if all else fails I will look more into that. Thanks again for all the replies - I will post what I find.
Thanks again everyone. I contacted Yotayard and they said they have a "barrel full" of rear shock plate mounts. I ordered 2 so I should be all set. No doubt wyoming9, I plan to cut those old u-bolts off! Thanks again for the help.
MMA_Alex
25
04-18-2017 05:07 AM
WTB[WestCanada]: 1989 4runner stock front bumper and other items
lledwod
08-30-2016 01:03 PM
icentropy
07-11-2015 07:21 AM
