Lost Power after playin in the mud HELP.
Old 11-22-2009, 06:10 AM
Bojangles's Avatar
I know this is alot to read but bear with me i need help BAD!!!
So i just bought a new Toyota (new to me)
1994 Toyota pickup 22re 4wd 4 inch lift and 33' Trail blazer medium tread.
411 gears in the rear and front. Brand spankin new motor, brand new transmission, they both have 800 miles on them, and both are still under warranty. It ran good as new for the first three days, it would burn the tires with no problem, wet or dry asphalt.
It would run a 100 easy.
I said all of that to say this...
I took it through the mud last night, Barely any.
I played for about 20 minutes and then took it home and washed it, i noticed on the way home it was running a little sluggish. Well i got home and washed it, and had to run uptown, when i left the driveway it felt like i had a really heavy trailer behind me, almost like i was dragging an anchor.
I run through first second and go into third, if i hold it half throttle in third and wait till 2800 rpm's it feels like the motor kicks in and it starts speedin up ALOT faster. The tires will not spin if i dump the clutch, which is not normal.
Ive lost all of my oomph if you get what im saying, I need help yall. How bout it?
Old 11-22-2009, 06:34 AM
blue_CA_yota's Avatar
Check your air filter.. prolly all clogged up with mud and dirt..
Old 11-22-2009, 06:38 AM
Bojangles's Avatar
I did, and its just as clean as when i put it in. Its a brand new air filter.
Old 11-22-2009, 06:48 AM
Built2Grind's Avatar
check your o2 sensor, make sure the connection is clean and dry, make sure your wash the undercarriage really good while your down there, mud makes rust happen faster.
Old 11-22-2009, 06:52 AM
Bojangles's Avatar
Ima have to check that, one thing i noticed before i bought the truck, the boy before me cut the Oxygen sensor out of the cat converter under the truck, which could be screwin it up, But that wouldn't explain why it would run Perfect the first few days and Frigg up in one hour.
Where would the O2 sensor be located on a 22re?
Old 11-22-2009, 07:08 AM
yoterr's Avatar
could have takin the ECU that long to notice and start dumping power??...check under the hood for loose connections, is ur check engine light on?
Old 11-22-2009, 07:10 AM
Bojangles's Avatar
Yeah has been since i bought the truck a few days ago, i took it to the shop and had them check it out and run a diagnostics check for like 40 bucks and they said their computer could not recognize my computer or something.
Thats whats worrying me a little bit, why would the same place that put the brand new motor in for me not be able to read the computer in my truck????
Old 11-22-2009, 07:12 AM
yoterr's Avatar
cuz its old...lmao hang on ill get you the link so you can do it yourself easy as pie
Old 11-22-2009, 07:13 AM
Bojangles's Avatar
Haha Well its a brand new motor i figured putting a brand new motor in the truck they might have gone the extra couple hundred bucks and had a new computer installed but i shoulda known better then that lol Thanks
Old 11-22-2009, 07:16 AM
yoterr's Avatar
try this http://www.troublecodes.net/Toyota/
and theres more stuff you can learn lol, greatest thing ive seen ever
http://pirate4x4.com/forum/showthread.php?t=775780 scroll down to EFI theres more links to sites
Old 11-22-2009, 07:17 AM
yoterr's Avatar
new or not still 20 year old technology 96 n newer they can read with scan tools
Old 11-22-2009, 07:27 AM
Bojangles's Avatar
Lol true. That link is gonna help alot appreciate it. I was actually watching an episode on speed this mornin about how to check the diagnostics with a paper clip just like this column says to do.
Old 11-22-2009, 08:26 AM
Bojangles's Avatar
I called the guy i bought it from he said the oxygen sensor was not cut when he sold it to me. Now whether or not he's lyin i dont know, but its possible it got caught on something and popped the wires. It doesn't look like a clean cut.
So i think i might put a new oxygen sensor in it, it cant hurt i need one anyways.
Old 11-22-2009, 08:42 AM
93yotaSR5's Avatar
Are the wheels full of mud? My 3vze did the same thing until I cleaned te 40 pounds of mud out of the wheels.
Old 11-22-2009, 08:44 AM
Bojangles's Avatar
Gawd dang! lol no its been washed 3 times and still rides the same.
Im at work now, kinda slipped outside and washed the underside while no one was looking. I had a little bit of mud come out, but nothing that would cause the kinda problem im having.
Old 11-22-2009, 10:03 AM
Bojangles's Avatar
Well i just left work to go get lunch, and it stranded me. It sounds like its runnin on 2 cylinders, i cleaned the distributor cap out cleaned all the plug wires, after work i reckon ill check the plugs to see if they are fouled out.
It didn't start doing this until i got a couple gallons of gas at sunoco, and if i have water in my tank ima be severely pissed
Old 11-22-2009, 10:17 AM
iamsuperbleeder's Avatar
this sounds familiar for some reason
check all your electrical sensor plug-ins, like the TPS, AFM, ignitor, ect; sounds like some water may have made it's way into one
Just FYI, although really fun sometimes, playing in the mud a lot REALLY kills the truck... mud finds it's way everywhere, into every crack and crevice, dry's up, tears apart seals and then bearings, and not to mention the water slug up finds it's way to all the electronics somehow... not preaching to you, just speaking from experience...
Old 11-22-2009, 10:22 AM
Bojangles's Avatar
Alright ill do that, sounds like you've had this problem before?
Old 11-22-2009, 11:29 AM
eh, kinda. that was one of my symptoms
I was having all kinda issues with my 22re at one time, and I ended up REMOVING THE UPPER MANIFOLD and cleaning it (search "black goo" and you'll see what I'm talking about), which got a little more power back, but the "sudden nitrous feeling at 3500 RPMs" didn't go away until I replaced my damaged AFM, which I killed while, you guess it, mudding had a wave of watery-mud come over my hood, choked the engine out, soaked the air filter and sucked in some water into the engine... the AFM does not like moister...
well on second thought, that, plus a new O2 sensor, and the problem went away... but I contribute my bad O2 sensor to the bad AFM making the engine run rich and taking out the O2 sensor
Old 11-22-2009, 11:53 AM
TOYOTA 1's Avatar
yea but thats just your worthless opinion
Quick Reply: Lost Power after playin in the mud HELP.
