longfield question for those who have them
Old 04-13-2010, 04:14 AM
jimep's Avatar
Just got mine in and test fitted them. They didn't seem to rub inside the knuckle unless i push them in a little. I even bolted everything up to the hub on the one side just to make sure. It seemed ok that way with the c clip on. Just curious if I'm checking it right. Who else didn't have to do any grinding?
Old 04-13-2010, 04:49 AM
waskillywabbit's Avatar
Typically you shouldn't have to grind the inside of the knuckle ball. Did you follow the install instructions Bobby has posted? Installed dozens of sets and I think I had to grind out one knuckle ball and that was very minimal.
Old 04-14-2010, 04:10 AM
jimep's Avatar
Thanks Wabbit. That's exactly the answer I was looking for. Guess I'm good to throw it together now. His directions say you "may" have to do some grinding usually on the lower side since his bell is a little larger than the stock ones. That's why I was asking how common it was to have to grind.
A2theK
01-10-2016 10:18 AM
makemusic116
08-02-2015 05:23 PM
makemusic116
08-02-2015 04:40 AM
TJWilly
07-31-2015 02:05 PM
4Runnin2000
07-29-2015 06:09 PM
Quick Reply: longfield question for those who have them
