long start
Old 02-06-2009, 03:23 PM
mrtrd103's Avatar
long start
i have a 94 4runner and for some reason when i try to start it, it takes a while to start. i can understand in the morning because it is cold and the truck has been sitting for a while, but why is it that within an hour it takes a while to start. please tell me what it might be and also a smell of gas keeps coming i don't know were or maybe its burnt oil but it smells really bad. what could that be
thanx in advance
Old 02-06-2009, 04:24 PM
fireman1559's Avatar
it could be lots of things like your iginitor could be going out the cold start injector could be on its way out why you smell gas it could be dumping it in the cylinders and flooding it out you just need to check to see if you have any codes its something to do with you ignition cause if you smell gas something is not firing right away and what happend to me when i smelt gas was when my iginitor went out it would just cran and crank never turned over it was just dumping fuel in and it was a very strong smell and if its your iginitor it will go out on you at the worst time mine went out on me going 40mph down a busy road.i dont know what motor you have but here is some troubleshooting for you the first one is for the 22re=>http://www.ncttora.com/fsm/1993/engine/3troubles.pdf the next one is for the 3.0=>http://www.ncttora.com/fsm/1993/engine/63troubles.pdf
Old 02-07-2009, 04:54 AM
mrtrd103's Avatar
thanks i found out today it was the fuel filter and spark plugs also the ignition wire basic tune up thanks for the advice much appreciated
Old 02-07-2009, 02:13 PM
mrtrd103's Avatar
i thought the problem was solve but after waiting for 3 hours went out and start the truck and it took at least 30 sec to start and it still have the gassy smell. i did a full tune up. man I NEED HELP. what is and ignitor i might NEED A NEW ONE AND WERE IS IT
HELP PLEASE
Old 02-07-2009, 02:42 PM
Junkers88's Avatar
I had this exact issue with my truck (1986 and a 22re motor) and it turned out that one of the little "O" rings on one of the injectors had failed. It would spray a little fuel out while it was running, thus the gas smell, and then wouldn't keep pressure when it sat for a little while, thus it'd take several cranks to fire back up.
Hope this helps.
Old 02-07-2009, 07:25 PM
i agree with junkers i didnt think of that it makes sense check that
Old 02-08-2009, 02:50 AM
mrtrd103's Avatar
sweet thanks guys im gonna head out today and check that out much appreciated
Old 02-08-2009, 04:49 AM
Toyota Pete's Avatar
If the other things don't work check your fuel pressure regulator. It can cause the problem you describe. Pull the vacuum line off it, If there is gas in the line the diaphragm in the regulator is bad. If not a fuel press. check is next.
Old 02-09-2009, 02:04 AM
mrtrd103's Avatar
actually one of the gas line that goes to one of the fuel injectors broke. its actually hard to get to its under the intake manifold so i brought it to ttoyota of newport and there gonna fix it for 400. i would have done it but would took to long i needed the truck for school. thanks for all the advice u all gave me
Old 02-09-2009, 08:00 AM
Junkers88's Avatar
Are you sure you don't have time to do it yourself? Taking the intake plenum off takes less than an hour, the fuel rail for the injectors only has one bolt on it and it's easy as pie to remove once the plenum is out of the way.
Or is the truck already at the dealership?
Old 02-09-2009, 02:47 PM
mrtrd103's Avatar
[QUOTE=Junkers88;51053839]Are you sure you don't have time to do it yourself? Taking the intake plenum off takes less than an hour, the fuel rail for the injectors only has one bolt on it and it's easy as pie to remove once the plenum is out of the way.
Or is the truck already at the dealership?[/QUOT
i would do it my self but the the fuel rail under the intake manifold is leaking and it takes a bit to fix it. the dealer called me today and said the fuel rail was broken under the intake manifold. the guy said he will charge me 200 to do everything. and plus with school and work i have no time. im driving my 05 tacoma right now
06-01-2021 01:51 PM
coryc85
09-09-2015 06:24 AM
colinmil
07-06-2015 04:03 PM
ptb12
07-05-2015 01:49 PM
Quick Reply: long start
