Left tail lignt only
Old 10-26-2014, 07:01 AM
f350 ff's Avatar
Hello folks,
I have been having an issue for a while now and need to get to the bottom of it before I get in trouble with the law. Simply put my left tail light does not illuminate. The brake, turn, and reverse all work on the left side, everything works on the right side, and the license plate lights work as well. I started when I went to replace a bad bulb in the original assembly and saw that everything was toasted (bad sockets, brittle/broken plastic) so I bought new replacement assemblies and installed them. Since then, and with a different replacement assembly, my left taillight will not light up. I have to think that it is some sort of ground issue, but then I would think that the brake would also be affected. Got any ideas? Please let me know. Thank you.
matt z
Old 10-26-2014, 07:24 AM
wyoming9's Avatar
Red face
Test with your multimeter see if you have voltage to the tail light socket.
Did you put the correct bulb in 1157?? is it installed correct.??
I have seen both these things done.
Damge to the plugs were they join together a little corrosion can cause problems.
Have a trailer light converter box ?? These seem to give no ends of problems .
Ground well the brake light and tail lights have different grounds
Be nice to know just what your looking at here???
Old 10-26-2014, 09:36 AM
f350 ff's Avatar
Yes it is the correct bulb, and it is installed correctly, I guess it's time to get the multimeter out. I hate chasing electrical gremlins so this will not be fun. Ok thanks again.
Old 10-26-2014, 11:14 AM
f350 ff's Avatar
turns out I had a broken wire, thanks
Old 10-26-2014, 12:40 PM
Odin's Avatar
Please tell me you didn't use crimp butt connectors. That's just asking for corrosion or contact problems down the road.
justdifferentials
Just Differentials
06-13-2022 07:40 PM
some drunk guy
08-03-2021 06:09 PM
user 82300
09-22-2015 07:00 AM
Ricu_air
09-19-2015 05:35 AM
Boomer8404
09-17-2015 07:59 AM
Quick Reply: Left tail lignt only
