leak between trans and transfer case?
Old 07-18-2016, 05:55 AM
MOguy's Avatar
I asked this question in another post I started but wasn't sure if it should be a new post because it was a new question.
I am looking at an 86 Toyota pickup to buy. One of the issues is a leak where the transmission and transfer case come together. It is a 5 speed so I think the transmission oil should be clearer or brownish and the transfer case red. The fluid leaking is red.
I am searching for info on this and find allot about a leak at the trail of the tcase but nothing where the tcase and trans come together.
Old 07-18-2016, 08:03 AM
RJR
RJR's Avatar
Generally the 5-speed transmission and the transfer case use the same type of lubricant, a GL-4 (preferred for the synchros) or GL-5 (acceptable according to Toyota.) While the PO may have put different oil in the xfer case vs. the tranny, I don't think you can say the leak is one or the other based on fluid color. Mine has the same stuff in both.
Old 07-18-2016, 08:08 AM
MOguy's Avatar
Thanks,
How difficult is it to replace the seals? I suppose the best thing would be to do both at the same time?
Old 07-18-2016, 08:21 AM
RJR
RJR's Avatar
The generally accepted method of separating the transfer case from the tranny is to start by pulling the transmission. I'm not sure if it's possible to separate the xfer case with the transmission still in the vehicle. As you can imagine, pulling the tranny is a fairly major project. Figure $600-800 for a shop to do it, plus the cost of separating the transfer case from the transmission and replacing the seals. If you're into it that far you'll probably want to replace the clutch at the same time.
Old 07-18-2016, 10:12 AM
MOguy's Avatar
Local shop only wants 125-150 depending on the seals.
It looks allot easier to separate the Tcase from the trans than the trans from the motor.
Old 07-18-2016, 10:17 AM
RJR
RJR's Avatar
That's great. I wasn't sure just pulling the transfer case was possible. If it is that looks like the way to go.
Old 07-19-2016, 05:23 AM
Flash319's Avatar
The transfer case has no seal into the center section. Oil from the transfer case can go into that section where you are leaking. There is a seal on the trans output shaft into that section. That seal is fine i bet. Just the gasket has had it causing the oil from the transfer case to seep out.
If it were me i would drain the transfer case oil, loosen all the bolts that hold it to the trans, put a jack under it, take out the cross member bolts from the frame and slide the transfer case back 1/2 inch. Clean the surfaces, apply some gasket maker and bolt back together.
If your trans oil level is not dropping then the seal on the back of the trans is fine. If that seal is leaking all your trans oil will go to the transfer case after a while, filling the transfer case with oil.
Old 07-19-2016, 07:58 PM
MOguy's Avatar
I found the leak. It is coming from the top where the 4wd selector goes into the tcase.
Old 07-20-2016, 12:02 AM
wyoming9's Avatar
Plugged vent more then likely or some one filled it from the top
Old 07-20-2016, 02:25 AM
MOguy's Avatar
Any info or a link on ways to fix it?
Nuckinfut
11-15-2013 06:57 AM
passingwind
01-26-2012 01:21 PM
jener8tionx
08-11-2011 05:42 PM
BackGateYota92
05-31-2010 12:47 PM
pray4surf
05-13-2008 08:00 AM
Quick Reply: leak between trans and transfer case?
