Leaf springs; replace or re-arch?
Old 04-01-2006, 05:53 PM
Citizencruz's Avatar
Question Leaf springs; replace or re-arch?
I am planning on running 32's and I don't want a full lift. I was just going to go the T-bar/ AALS route. Whwn I was under my rig earlier today, I noticed the stock springs looked a little tired. A buddy said I could always re-arch them. Is this a good idea? What are the pro's and con's?
Thanks,
Jack
Old 04-01-2006, 08:01 PM
wrenchmonster's Avatar
It all depends... the guys who re-arch springs will tell you they are good as new. And springs on heavy trucks (class 6 and 8) get re-arched all the time.
In my humble opinion, re-arching is a cost savings technique. My belief is that metal fatigues over time, particularly spring steel, hence the whole reason springs get worn out.
I have had luck re-arching springs and adding an extra leaf or two. This is kind of a compromise between getting all new vs. just re-arching the old springs. In my particular application, this rig was used mainly for heavy trailering, so it was a good excuse to beef up the stiffness by adding the extra leaves.
If you decide to re-arch, make sure to tell the spring guys how much lift you want, and if you want a soft spring ride or a stiff spring.
Old 04-01-2006, 08:06 PM
4runnermt's Avatar
If you get them re-arched, definately like wrenchmonster says to tell the spring guys how much lift you want. My friends '68 scout sits crooked since the guys re-arched the springs. He only brought one side in at a time, and consequently they are different!
Old 04-01-2006, 09:47 PM
RustBucket's Avatar
I rearched and AALed mine recently, and I am happy with the results. It is probably true that the metal does fatigue and its spring constant is probably different even with a re-arch, but then again, we are talking about thick pieces of steel, and I can't imagine them changing all that much. I mean, if it takes 10 years for the springs to sag first and then after re-arch it takes like 8, so what?
Old 04-01-2006, 10:49 PM
smiljko's Avatar
I've had bad luck with rearching springs on my previous Daihatsu Rocky-after rearching they decided to break.
Old 04-02-2006, 06:08 AM
Joyota's Avatar
Another thing you could try is something ZUK came up with. He mounted coil springs in between the frame and the u-bolt mounts. It's what I plan on doing to mine
Here's a link to his write-up on it. He might be willing to make up more for sale.
WARNING: 34 pictures the size of the one below!
http://gearinstalls.com/dc.htm
Old 04-02-2006, 09:15 AM
Awesome! Thanks!
Old 04-02-2006, 11:22 AM
CoedNaked's Avatar
Have there been any issues with those coils popping off during articulation?
Old 04-02-2006, 04:09 PM
Joyota's Avatar
If you look at the pictures on that page, he shows that he has added a self-capture feature to prevent the coils from popping off. The last picture also boasts increased articulation.
Old 04-02-2006, 04:25 PM
surf4runner's Avatar
re-arch and add another leaf too
Old 04-02-2006, 05:22 PM
AH64ID's Avatar
I have had bad luck with AAL. I have known a couple of guys who have had their rearched, and after one good weekend flexing on the trail half the lift was lost. Also if you rearch your stock length springs for 2" lift, they will make the shackle angle steeper, stiffer ride, since they are only long enough for stock height.
Persoanlly, new springs
Old 04-02-2006, 05:41 PM
CoedNaked's Avatar
I personally agree with new springs too. Then you could get something built to work together, and you won't have any doubts (as long as the spring manufacturer/install was done in a reputable fashion). Plus it'll be something new, and cool.
I have all new springs on my truck, plus an extra leaf (so I have a 4 pack plus 1 overload) and while it's not the best unloaded, a little harsh, some fishing gear back there and a buddy going fishing and it rides fine. It also articulates descent.
I'm not a fan of having second thoughts - are you?
Old 04-02-2006, 06:03 PM
yotaknows's Avatar
What about using air bags or air shocks to get the lift back?
Old 04-02-2006, 06:32 PM
AH64ID's Avatar
I plan to use some gabriel airshocks to keep me level to and from the trail when I am full of camping gear. I currently have some Alcans, 56", that are 4.5" of lift. I had them built for my 95 runner, so on my 92 reg cab they are a bit stiff....I am going to sell my Alcans, and get some Allpros, and use airshocks to keep me from running on the bumpstops when loaded. I will then remove them when I get to the campsite. I plan to weld in extra shock mounts so I dont have to remove my ranchos when the airshocks are in.
Old 04-02-2006, 08:22 PM
BLKNBLU's Avatar
How much does re-arching cost?
Old 04-03-2006, 04:58 AM
RustBucket's Avatar
whoa, cool coil springs!
Old 07-17-2019, 05:03 PM
trevdog's Avatar
I had my springs re-arched while I was doing my 3.4 swap. I asked the shop that they return them to stock height, and they might have been slightly better at first (hard to tell as I did a 2" body lift and 33" tires at the same time). Now I'm shopping for a fix to my sagging rear end and wishing I'd saved the money of a re-arch and new bushings. Perhaps the 300K+ miles, heavy loads and youthful abuse just wore out the original steel. The Zuk mod looks ok, but if my original leafs are that tired...
At this point I'm leaning towards new leafs and airbags. It looks like the OME only comes with a 2" lift though, so there's a bit more research to do. If anyone has airbags and an onboard compressor, I'd love to hear where everything is mounted.
Old 07-17-2019, 05:22 PM
RAD4Runner's Avatar
Originally Posted by trevdog
...The Zuk mod looks ok, ....
The $70 Zuk mod on my 33-YO truck has taken my to many wild and beautiful places, while many fancy trucks had been stuck between the mall and the office.
Stock height.
The following users liked this post:
millball (07-18-2019)
Old 07-18-2019, 05:19 AM
HotNotch's Avatar
Ran a Zuk mod for years with factory, 250K mile springs. Would definitely do it again in the future.
Old 07-18-2019, 11:39 AM
old87yota's Avatar
I like the new springs and air bags idea myself!
Plus, installing new leaf springs would be a proper repair.
Flying91
45
04-11-2024 04:39 PM
TURBOrunnerNM
07-22-2015 11:01 AM
cars-guy
07-11-2015 07:51 PM
Nickdigg
07-07-2015 06:04 AM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: Leaf springs; replace or re-arch?
