Leaf bolt?
Old Jun 26, 2008 | 03:23 PM
1992toyota4x4's Avatar
Leaf bolt?
ive been wondering about adding rear leaf springs to my 92 pickup, and someone said that is shouldnt be a problem as long as the center bolt is long enough, well i looked last night, and neither side has a bolt through the middle, just 2 u bolts bolted to the axle and go around the leafs, is this normal, and is it a problem?
Old Jun 26, 2008 | 03:50 PM
91 4Runner's Avatar
There should be a centering pin that goes through the springs into the spring perch. If there isn't you run the risk of your axle shifting.
Old Jun 26, 2008 | 04:34 PM
where can i get a bolt for that? anywhere?
Old Jun 27, 2008 | 03:42 AM
WFO's Avatar
WFO
I know around here Pep Boys has them. Id imagine if you couldnt find anything you could always grind the head of a bolt (whatever size it may be) to make it fit snug in the perch.
Old Jun 27, 2008 | 04:13 AM
ssupercoolss's Avatar
basically a really long grade 8 bolt will do. cut it down after you put it back together. you may want to clamp the springs in a really big c clamp, so as to not let them fly apart on you.
Old Jun 27, 2008 | 03:28 PM
nvm mine has them lol, i didnt look very good.
nvdesertrunner
May 11, 2020 08:18 PM
Kreedy1
Sep 8, 2015 06:33 PM
eggens
Sep 5, 2015 12:16 AM
Aaron Logan
Sep 3, 2015 08:08 AM
Ryall
Sep 2, 2015 06:48 AM
