knock knock
Old 12-01-2010, 07:25 PM
xtultegra's Avatar
knock knock
22re 1990
I have a knock that I can plainly hear when I am driving. It sounds just like a loose valve only a bit louder. It increases in frequency with rpms. It is not a bent valve and it is not a rod bearing. It is much higher pitched than a rod bearing. I have adjusted the valves at least 8 times and it makes no difference. With a stethoscope the sound is loudest at the exhaust manifold. I searched for a leak there and all down the exhaust and can find nothing. I can't hear it with the scope at the valve cover because the valve noise drowns it out. I can barely hear it from the bottom of the block. Other than that the truck runs great.
The noise seems loudest at 1500 rpms. I believe it increases in frequency above that so that it just blends in with sound of the motor. At idle it is noticeable but just barely.
As I said, the knock is the most noticeable when behind the wheel. If I turn on the air or heater, I cannot hear it. It's harder to hear when outside the car. Makes no difference if the truck is in gear.
Any ideas? Wrist pin?
Old 12-01-2010, 09:17 PM
gyoas759's Avatar
Maybe post a video with the sound so we can hear it?
Sounds similar to a knock on a Dodge Durango I had a year ago. Scared me when it started making noise. Turned out to be a small leak along one of the header pipes.
moparbay
03-10-2023 03:50 PM
some drunk guy
08-03-2021 06:09 PM
Marley2984
12-06-2015 05:19 AM
moparbay
10-06-2015 09:24 AM
ac7822
09-11-2015 08:49 AM
Quick Reply: knock knock
