YotaTech Forums
Go Back   YotaTech Forums > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Sign in using an external account
Register Forgot Password?
Search
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 11-26-2007, 06:25 AM   #1 (permalink)
Personal Sales Rating: (0)
acerbis's Avatar
kind of slow
just bought a 87 22r. It has 31's o it and the gear spacing seems to be wide. 5th gear is only for 70mph and up! there is no way that i can crawl in first. Do you guys think i need to put a different gear in the rear?? like a 4.56? thanks
acerbis is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 11-26-2007, 12:16 PM   #2 (permalink)
Personal Sales Rating: (1)
TORTIS's Avatar
31's are the limit for the 4;10 gears. i think your 4:56's are good if you are going to stay at 31's to 33's, but 33's would work with 4:88's. there is a gear calculator somewhere on here that will help you. you could drop a 4:70 low gear in your t-case. and keep the 4:10's
__________________
89 Truck X-tra Cab
LCE Timing Chain
LCE Header
31'' Maxxis Buckshot
4.88's built by ZUK(the mind reader)
Aussie Locker Front and Rear
63'' Chevy Springs
Marlin HD Clutch
Bilstein HD Shocks
2.5" Exhaust W/Dynomax Muffler
2-50 Watt Backup Lights
TORTIS is offline
Old 11-26-2007, 01:39 PM   #3 (permalink)
Threadstarter [OP]
acerbis's Avatar
So 4:10's are stock? Each gear seems so long. Like the whole trans needs to be shortened. Or is that because i have a 22r? I just have to slip the clutch too much to take off. Care to explain about that 4:70 low gear or maybe direct me to a link that will? thanks!
acerbis is offline
Old 11-26-2007, 04:01 PM   #4 (permalink)
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
First off, you can't regear just the rear. You'd have to do both diffs if you ever plan on using 4wd.
Second, I drive a 22re 5spd 4rnr and I can "crawl" plenty well. (Though, I don't "crawl"....I just have to get in and out of my driveway ) And clutching is no problem at all even living where I do....in the Ozarks. I can easily do 50 on up on flat stretches. Sometimes 45....if it's real flat. I'm usually in 4th for those speeds, though, with all the hills around here. So, I really don't see how you can't get the same with your vehicle with the same tires and engine.
Third, given what I've said, I'd have to say you have a power issue at the engine side of things if you can't push 31's easily. For "crawling", though, are you trying to crawl in low 4wd or high?
BTW, 4.10's would be stock on yours. It is on mine, too.
__________________
Matthew
Context is everything....
Quote:
Originally Posted by abecedarian View Post
freckles, shmeckles... that was your acne reflecting on my pearlescent skin.
My favorite method of troubleshooting..... :D
Quote:
Originally Posted by HighLux View Post
Oh...that was me thinking...then stopping mid sentence...then some more babbling and such. LOL
thook is offline
Old 11-26-2007, 04:04 PM   #5 (permalink)
thook's Avatar
Wait...wait...wait. Back up a minute, here. Do you even have a 4wd? If not, that would explain part of it. If so, I'm wondering if someone swapped the gears out.....if you don't have any engine power issues.
__________________
Matthew
thook is offline
Old 11-26-2007, 04:08 PM   #6 (permalink)
bob200587's Avatar
bob200587
Yea, 5th gear is not gonna be very useful with 4.10s and 31's. Mostly only on flat ground. But, most cruising is supposed to be at a relatively high rpm. I find 2700-3100 to be about the right area.
4.56 gears will fix it, but it sounds like something isn't right with your motor as well if you can't take off without excessive clutching.
__________________
<===This picture is me and my 4runner when I was about 4 years old.
87 4runner 4x4 SR5 22RE
ARB Bull Bar,
31X10.50 Mastercraft M/T's, Stock 4.10 Gears, Flowmaster Muffler, LCE Header
AISIN Manual Hubs, Marlin Crawler Sliders
Dead motor 3.4 swap or something else to come
bob200587 is offline
Old 11-27-2007, 05:15 AM   #7 (permalink)
Threadstarter [OP]
acerbis's Avatar
its a 4x4. once i get going it seems fine. its just that initial going from a stop. There are headers on there so i'm not sure if i can do the whole block off plate for the egr. I was trying to look last night but couldn't see anything. Maybe if i take off a heat sheild. Once i'm moving the rest of first through 4 is fine. I do have to rev it out a bit for each gear. I'm also going to replace the fuel filiter.
acerbis is offline
Old 11-27-2007, 06:37 AM   #8 (permalink)
AxleIke's Avatar
Its probably the 31's. Do a tune up and see, because it seems like you are TOO slow, even for 31's and stock gears.
I suppose it would be good to know your background? Have you driven toy trucks before? Because they are pretty gutless. If you are used to high power vehicles, these seem like they are awful. They do require a tiny bit of clutch slip to get going, but hardly any at all.
Also, you say you can't "crawl" in first. That is pretty strange. You are in low range, correct?
__________________
Supercharged 1999 4Runner- Baby Beast 2, the mild mannered build-Link
1987 Mutant 4runner|Slightly Modified|Lacking general build direction|Now on 35's-Parts truck-SOLD
1989 Project 4runner-The Redo-SOLD
-Lifts and Tires look cool at the Mall, Lockers and Gears look cool on the trail.
-Internet Nice Guy
AxleIke is offline
Old 11-27-2007, 07:39 AM   #9 (permalink)
jason191918's Avatar
jason freudigmann
Send a message via ICQ to jason191918 Send a message via AIM to jason191918 Send a message via MSN to jason191918 Send a message via Yahoo to jason191918
if the truck came with the 31" option, then it should have 4.56. If it had the standard tires, then it should have 4.10. Tortis was right with his post.
This site should tell you how to identify your ratio:
http://www.brian894x4.com/Gearratiosanddiffs.html
Here is a calculator:
http://www.4lo.com/4LoCalc.htm
J
__________________
JASON
1992 Pickup V6, 4x4, 5 speed, SR5, 300,000 miles young, every option except automatic tranny
31x10.5R15 | K&N FIPK | Cherry Bomb | 3" BL | 4 110W KC Light Bar | 6'6" Western Plow | 800W 10" Sony | 850W Sound Storm | 2 4" Obcon | 4 1" Rockford Fosgate Tweeters | 2 High Pass Crossovers | 2 High-Low Pass Crossovers | 2 6.5" Rockford Fosgate | Pioneer 4x50W Head Unit | Mechanical Oil Pressure Gage | Lack of EGR | Blinker Mod
Quote:
Originally Posted by Elvota View Post
Jason is right.
Quote:
Originally Posted by fishon1213 View Post
Jason rocks!!! :banger:
jason191918 is offline
Old 11-27-2007, 10:09 AM   #10 (permalink)
Threadstarter [OP]
acerbis's Avatar
Thanks for all of the help so far. I am use to something a little faster but its not the lack of pull. Its the clutch slippage. I'd say that it takes 2 or more seconds to let the clutch out. If i let it out all at once then the truck will bog. I've ridden dirt bikes for many years and it seems like super tall gearing. No doubt. because 5th could probally reach 100+. But thats if there was a downhill. anything but flat and i have to go to fourth. I don't have a tach installed yyet but 3rd is good (stops pulling) till 55... i just cruz in 4th. And 5th is super gas saver mode!! I'll check compression this weekend and do a fuel filter. Maybe even valve clearance.
I replaced the plugs and wires. The number 2 cylinder had so much carbon deposits it was crazy. I put two bottles of seafoam and it runs better. With aftermarket headers you don't have a egr..right?
So blistien shocks with new bushings or just go for the ome 800$ kit?
acerbis is offline
Old 11-27-2007, 10:17 AM   #11 (permalink)
infiltrator's Avatar
Send a message via AIM to infiltrator
what are the stock gears for my truck. i also have a 2wd and run 31's
__________________
Old Rig: '95 4runner | White | ISR | 193,000mi. | Totalled.
infiltrator is offline
Old 11-27-2007, 11:10 AM   #12 (permalink)
Threadstarter [OP]
acerbis's Avatar
and its a 4x4. I'm not even 4 wheeling yet. just trying to work out some bugs.
acerbis is offline
Old 11-27-2007, 11:15 AM   #13 (permalink)
AxleIke's Avatar
Well, that is a little longer than my clutch, but not much. You can't just dump the clutches on these. You have to goose them a bit. FWIW, my truck has a brand new motor, is running tip top, and is actually over geared for the tires I'm running.
__________________
-Internet Nice Guy
AxleIke is offline
Yotatech
4WD Truck
Paid Advertisement
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
what kind of lift? yota7 Newbie Tech Section 14 01-08-2006 05:12 PM
Maybe the 3.slow and 22really slow can benifit form this fo_runner 95.5-2004 Tacomas & 96-2002 4Runners 8 08-04-2005 07:35 PM
what kind of battery? rivercat 95.5-2004 Tacomas & 96-2002 4Runners 18 01-20-2005 03:43 PM
What kind of shocks? DrummerDaveB 95.5-2004 Tacomas & 96-2002 4Runners 16 09-14-2003 06:42 AM
What kind of dog should I get? INsr5runner Off Topic Talk 34 07-10-2003 10:04 AM
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
