a jingle noise from engine
Old 01-25-2012, 08:38 PM
shafner30's Avatar
hello
i am getting a jingle noise in engine at diffence rpms
the noise is coming frome the driver side..
i got a 1990 22re 2wd
any idea?
Old 01-25-2012, 08:56 PM
cman1's Avatar
probably your cat heat shield or check your exaust clamp right under the exaust manifold,i believe it bolts to a bellhousing bolt.
Old 01-26-2012, 03:17 AM
rattlewagon's Avatar
Does it make the noise when its idling?
Have you looked at all for the noise yet? if so what have you checked?
Old 01-26-2012, 03:40 AM
Bassmastry101's Avatar
Are your bolts on your collector loose? Maybe the heat shield on the frame is touching the exhaust and rattling.
Old 01-26-2012, 06:34 AM
shafner30's Avatar
no it does not do in idling mode
Old 01-26-2012, 07:24 AM
combatcarl's Avatar
Yeah, I've got the same (I think) sound. More noticeable on downshifts? I don't know the rpm range but most noticeable in 3rd under decel. About 35 down to 30, but I can hear it 4th thru 2nd. If I figure it out, I'll share. Think its just exhaust related noise tho.
Old 01-26-2012, 07:29 AM
snobdds's Avatar
Sounds and noises are almost impossible to diagnoise over this world wide web thingy. It is a shot in the dark, at best, and your vague description does not help a whole lot. If you want some serious help without a bunch of gusses, which is what your getting so far, your going to have to post up a video of this noise.
razorman8669
07-12-2015 12:13 PM
Jonny246
07-12-2015 04:51 AM
smiley52
07-11-2015 05:16 AM
Poncho0206
07-10-2015 06:21 PM
Gamble_STi
07-07-2015 07:54 PM
Quick Reply: a jingle noise from engine
