YotaTech Forums
Go Back   YotaTech Forums > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Sign in using an external account
Register Forgot Password?
Search
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 01-10-2013, 01:57 AM   #1 (permalink)
Personal Sales Rating: (0)
tysen86's Avatar
Input shaft bearing
My 91 sounds like it has a bearing going out in the tranny. I makes the sound in 1,2,3,5 and neutral. When I shift into 4th it's just as quiet and smooth as you could want. I have a couple questions; first, could an input shaft bearing be causing this and if so, why not 4th gear? Second, can a country boy like myself change and input shaft bearing or does it require some special pullers? The best way I know to explain the sound is, it sounds exactly like the throw out bearing did when it was shot and the clutch was let out. It's definitely a bearing.
While I got ya, if anyone knows where there is a tranny sitting in or around North Georgia, I could probly use it!!
tysen86 is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 01-10-2013, 02:26 AM   #2 (permalink)
Personal Sales Rating: (1)
Terrys87's Avatar
My spare tranny that I was hoping was good does just the oppistite of yours. All gears are great except 4th gear. Almost sounds like exact same noise you are saying only mine is 4th gear only.
I dont know about changing input shaft, but I to am on the hunt for a tranny.
__________________
Wifes 88 4Runner Rebuild Completed-Upgrading when possible. :)
http://www.yotatech.com/f199/terrys8...99/index8.html
My 86 4Runner Rebuild
http://www.yotatech.com/f199/terrys8...chance-247386/
My 85 Extra Cab Build
http://www.yotatech.com/f198/85-extr...rusher-263813/
Terrys87 is offline
Old 01-10-2013, 02:43 AM   #3 (permalink)
If it were the input shaft wouldn't make the noise in all gears? Just a thought. Have you checked the tranny oil?
hambob is offline
Old 01-10-2013, 03:31 AM   #4 (permalink)
Pat8942's Avatar
It could be the input pilot bearings, they are the rollers inside the input shaft, it would make noise in every gear except direct (4thgear) because the input turns a different speed than the output in every gear except direct.
Pat8942 is offline
Old 01-10-2013, 04:11 AM   #5 (permalink)
Threadstarter [OP]
tysen86's Avatar
Ok, so it could be the input pilot bearing, is this something I can change or do I need special tools?
Thanks for the input.
tysen86 is offline
Old 01-10-2013, 05:55 AM   #6 (permalink)
ThatGuy1295's Avatar
You probably could change it. But I would just have the whole trany rebuilt at this point. Way worth it, compared to changing out one bearing and having the next one go out later. Tearing a transmission out 4 times in 4 years is a joke.
ThatGuy1295 is offline
Old 01-10-2013, 07:02 AM   #7 (permalink)
Threadstarter [OP]
tysen86's Avatar
Yea, I'm looking for another tranny so I can have this one rebuilt.
tysen86 is offline
Old 01-10-2013, 12:04 PM   #8 (permalink)
Threadstarter [OP]
tysen86's Avatar
Ok, my next question is, how do I find out if I have a G or a W tranny? And is one better than the other?
tysen86 is offline
Old 01-10-2013, 12:05 PM   #9 (permalink)
Threadstarter [OP]
tysen86's Avatar
Oh, there is not a data tag on the firewall.
tysen86 is offline
Old 01-10-2013, 02:11 PM   #10 (permalink)
highonpottery's Avatar
mine had bad input shaft bearing. had noise in all gears but 4th, as well as in neutral (4th is direct gear) - sounded like marbles jangling around inside. decided it was best to just get it rebuilt. shop tech sent me a pic of my chewed up input shaft splines where 40-50% were broken off....yikes.
__________________
1993 X-Cab 4wd -- 2002 UZJ100 Land Cruiser -- 2001 Corolla S -- 2006 SV650s -- 2006 Accord Hybrid
Axial Toyota RC Scaler
highonpottery is offline
Old 01-13-2013, 02:39 PM   #11 (permalink)
Bigblock's Avatar
Could be the gears.4th really is not a gear so it cant make noise unless a bearing is bad.How much trans oil have you been adding?
Bigblock is offline
Old 01-13-2013, 02:45 PM   #12 (permalink)
Threadstarter [OP]
tysen86's Avatar
I added a quart yesterday. it don't ever leak. only leak on the truck is the rear main and its a small leak.
__________________
1991 PU bone stock.
Engine is bored .020, .010 off the head, .010 off the top of the block, ported, pollished, and completely ballanced (I think thats all, I can't remember). Just needs a cam.
"I understand the Jeep thing.....it's broke down!"
tysen86 is offline
Yotatech
4WD Truck
Paid Advertisement
Tags
04, 30, bad, bearing, corolla, cost, gear, input, l52, pickup, puller, replace, shaft, symptoms, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
