Inconsistent symptom no start
Old 05-24-2013, 10:10 PM
86pudlx's Avatar
My 86 22r pickup is having a no start problem. Some times it starts sometimes it wont, with no consistancy. When I can get it started i have to hit the gas pretty frequently to keep it running but it idles high(over 1500rpm then just stalls out). have been able to keep it running with artificial fuel.
It all started miss a few hard misses(like a dead cylinder) i pulled over and played with it it ran fine and responded to snap throttle beautifully, then just stalled and wouldn't start. I have good even compression 157psi. Runs the same with new rebuilt carb and old one (just sent back new one for over fueling). I have good fuel pressure most of the time( just replace fuel pump 2nd 1 in 2 months, for 0.5 lbs fuel pressure right after returning carb). 3rd clean fuel filter this year. Distributor tested good. However my coil secondary was .3 ohms high and my ignition module failed the initial power transistor test(not sure i was doing it right had no 0.00v reading), but the second test pull 10v as specified. i don't have the money to replace the module and something else at this point so I inquire for help.
Im testing my EGR tomorro
Any other ideas would be greatly appreciated!
Thank you
jbv808
08-06-2021 04:47 PM
Doug4320
03-24-2018 10:11 PM
Poncho0206
07-10-2015 06:21 PM
raiderhawks00
07-08-2015 06:23 PM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: Inconsistent symptom no start
