Ignition Issue
Old 10-19-2005, 02:28 PM
kb95's Avatar
Question Ignition Issue
I replaced the distributor cap, ignition wires, and rotors today. I believe I have the wires going where they should be, but when I go to start the vehicle it simply *click, click, click*s.
Does anyone have a diagram of the spark plug cables routing?
It's a 3.0 V6 by the way.
Old 10-19-2005, 02:52 PM
travelinman's Avatar
Does the starter turn the engine? It sounds like your battery is dead...
I think the firing order is on the underside of the hood, but I can't remember where the cylinder numbers are located; someone here will know.
Old 10-19-2005, 03:22 PM
jimbo74's Avatar
is the distributor accidentally flipped 180*?
Old 10-19-2005, 03:56 PM
kb95's Avatar
distributor is on correctly. I have 1 going to passenger side front cylinder, 2 to driver's side front, 3 passenger mid, 4 driver mid, and 5 passenger rear, and 6 driver's rear.
it does not appear to be turning the engine. just clicking away.
Old 10-19-2005, 04:03 PM
Well, if your engine is not turning then you have another problem. The battery/starter system is independent from the ignition system. The clicking is likely a symtom of a battery that does not have enough juice to turn the starter/engine. I'd check my wiring (that sounds right, what you have above, but I can't remember) then get a jump start. If the engine turns, but does not start then it could be something else (voltage reg/coil stuff/ etc...) My two cents...
Old 10-20-2005, 07:50 AM
kb95's Avatar
i took the cap off, removed the rotor to make sure it was on correctly. It does not appear the rotor has moved at all. I double checked the wires they seem to be going to the right location.
the battery is farely new, and it was starting just fine before replacing the rotor, cap and wires (just missing on a few cylinders).
It is fast clicking. Any other ideas? I'm going to try and get a jump later today.
Old 10-21-2005, 05:09 AM
kb95's Avatar
Still does the same thing when trying to jump start. I'm going to start troubleshooting the starter today.
Old 10-21-2005, 05:40 AM
I did have a starter die in my '90 4runner. I really don't remember what the symptoms were, but the clicking sounds familiar. It's a pretty easy replacement (there's a access panel in the right front wheel well). Good luck man!
MO transplant
04-23-2023 11:58 AM
Sleaker
08-26-2020 06:03 AM
80Truck
07-24-2015 03:12 PM
nickb3
07-21-2015 10:00 AM
94whiterunner
07-12-2015 07:15 PM
Quick Reply: Ignition Issue
