ifs steering box
it was all in a big plan I had when I had what I thought was a steady job...
was pulling in enough money a month to make a real truck payment, and I got tired of screwing with the Toy every week to make sure it was going to keep getting me to work; it was one thing after another; just little things that kept happening... but it was getting quite annoying...
so, I sold it locally, and went and picked this up:
THEN, a week later, the Toyota gods showed their disapproval and laid me off work lol
Well I've already check all the junkyards around town the earliest steering box they have is 89...kinda in rough shape all the way to 94 T100. I know they aren't an exact fit. can anyone shed light on upgrading to the newer style?
hey off topic for a sec, but where in Titusville are you? and what color truck do you have?
there's a black 2nd gen PU parked across the street from me here, and I'm wandering if MAYBE it's someone on the forums
#25
you dont need a gasket.. just pull it off and put it on.. its a toyota part.. its good for long time...
i just pulled a ifs power steering from my old 94 runner.. its going on my suzuki to push my hysteer yota axles...
took me 3 hours too pull but lots of rust and breaks too pull some tubes.
#26
I know the weekends over but I got a black extended cab. Let me see if i can scrounge up a pic. Thats it minus the boggers. I got black steelies and mud terrains now.
#27
looks just like that, 'cept there's a sticker on the front window that says "BINGO", and there's some other stickers on the back window (a Browning one, and some others), and there's no front bumper like that on it
but man that's close; I had to look at the pic twice! lol
#28
Ok so your steeering is loose, is it all in the steering box? How about your TRE's, ball joints, idler and pitman arms? Your box uses you hydro power to move the pitman arm to mak eit stear, basicly takes the work out of steering your truck and does it for you.
#29
just replaced the tie rods. the ball joints are good. but the pitman arm might be worn out still have a front end wobble i thought the tie rods would fix.
#31
Those items would fix your wobbly steering, new box wont fix that, but will improve the responsiveness, and not to mention leak all over the place.
#32
I got my pitman arm so I'm all ready for my gear box. If found a later model steering box from a 89 pickup for a really good deal. I wasn't wanting to have to modify anything but moneys tight so I got to go with the deal. I understand the later model steering boxes are an inch longer where the steering shaft meets the box. What modifying needs to be done? Can I just bolt it on or just take the steering shaft off the 89 too?
I know this thread might be drawn out because iv'e been working to much to find time to put into truck. I have done the searches and found no clear answer. I got all the tools to take everything off but i don't have any welding skills so let me know if this can or can't be done. thanks.
#34
Finished!!
For all those wondering the 89-95 steering box is a direct bolt on replacement part for the 86-87 pickups. All you have to do is shorten the steering shaft by loosening the bolt closest the firewall and feed it in an inch. If that doesn't work for you...you can even drill out the pins to shorten the shaft like so http://www.4crawler.com/4x4/ForSale/...#SteeringShaft but it shouldn't be needed. I'm really happy how it worked out. I found a used one for 40 bucks and have had no leaks so far (now use ATF), lost 6 inches of play in the steering wheel, and have found that it is a quicker ratio with the newer boxes. Only downfall is I haven't yet gotten the old pitman arm off. The advance auto pitman arm pullers break every time you use them.
#35
That pitman arm puller, how are you using it? I used one from Advance Auto (bought from the the store there on HW50 ) and I rebuilt my entire front end with it.
PM me if you need help; I'm in town for a few days, and I garantee you we could get if off there
#36
Well I'm sure I'm using it right. sliding it in between the box and the pitman arm and tightening the bolt. Iv'e popped a few off before but it just helps if the puller doesn't break. Its been taking so long to get stuff done between work but top priority right now is finding a new motor before i throw a rod.
#37
1) put the puller on, and tention it up with the bolt; get a pretty good amount of torque on it
2) take a hammer and hit the pitman arm firmly (strike the pitman arm right where it attaches to the shaft coming out of the gearbox)
3) repeat steps one and two several times until the pitman arm breaks free; the tentioning and hitting with the hammer will break the hold on the piman arm 9 out of 10 times
you want to strike the pitman arm here:
and this is the exact puller I used:
to create this
#39
I replaced the pitman arm on the junk yard unit, however using the "standard" pitman puller, I dang near broke the ends off because they started to bend and would not break loose hte pitman. The puller I had to use I also rented from Autozone but it was the heavy duty version of the OEM brand. The one pictured here:
http://contentinfo.autozone.com/znet...27170/image/4/
I had to tighten down the wing nuts pretty good with an an adjustable wrench and used a 12" 1/2" drive breaker bar and also rented a 32mm ??? axle nut socket.
With a little cursing along the way and bracing my foot up against the passenger side tow hook, I managed to get mine off.
Jcrawl94
10
10-24-2015 04:34 PM
delmert
09-30-2015 04:34 PM
FS[PacSouthWest]: FS: 1988 4RUNNER FRAME 4X4 IFS Located in Lancaster Ca
4x4-runner
08-30-2015 08:55 AM
