IFS BJ spacers, Upper & Lower Balljoint removal / install
#41
KAI32-- The grinding was minimal. Grind off some metal, test-fit the spacer and see if you removed enough material from the A-arm lip, repeat as necessary. Much simpler than you are probably imagining.
#44
#46
6 years later
Still have the pickup, and still impressed with the OME suspension. Had a little wobble in the front end that was due to out of balacne tires, and replaced the super cheap replacement idler arm with an OE part, no more wobble.
#47
Good to see this. My driver side BJ's grease/dust jacket has now started to leak and I see a little vertical play. Ordering replacements soon.
How was the condition of your upper BJ's compared to the lower ones? Reason I'm asking is I'm on a tight budget. Wanna replace the load-bearing AND obviously bad uppers first, then lowers later.
WTB[WestCanada]: 1989 4runner stock front bumper and other items
lledwod
08-30-2016 01:03 PM
09-04-2015 09:27 AM
FS[NorAtl]: set of 4 ball joints. any torsion bar ifs 4wd
akaphilly
07-09-2015 02:27 PM
