Idle Pulley Adjustment Bolt
Old 07-28-2010, 01:53 PM
Catamount's Avatar
95 3vze 4x4 pick up. The adjustment bolt on the AC compressor Idle Pulley keeps vibrating loose about every three months. I loosened or maybe removed it last winter to remove the drive belt while doing a water pump and timing belt. My Haynes manual doesn't indicate a lock washer, lock nut or set screw nor do I recall any. Seems thread lock and or a lock washer would fix it but want to be sure this isn't an indicator something more serious is wrong? Any advice would be appreciated.
Alex Bessinger
08-31-2015 09:17 AM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
yourrealdad
07-21-2015 11:13 AM
dinks07
07-15-2015 05:34 PM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: Idle Pulley Adjustment Bolt
