idle problems and cylinder misfire Plz Help!
Old 10-12-2005, 05:50 PM
adam86pickup's Avatar
Unhappy idle problems and cylinder misfire Plz Help!
i have an 86 toyota pickup with the 22rte motor in it. i have an idle problem. it has a very rough idle during and after warmup. the exhaust pipe shows that the engine is running very rich, you can smell it too. i now found that i am not firing on the fourth cylander. the cylander has spark, fuel, and compression. WHAT IS WRONG!
Old 10-13-2005, 12:23 AM
Elton's Avatar
how is the timing ?
Old 10-13-2005, 12:38 AM
jimbo74's Avatar
that cylinder probably has bad piston rings or burnt valves
Old 10-13-2005, 04:24 AM
MTL_4runner's Avatar
It obviously has fuel since you are smelling it in the exhaust.
How did you go about checking for spark and compression?
What was the compression in that cylinder?
What does the spark plug look like?
Have you tried another plug?
Old 10-23-2005, 12:29 AM
thanks anyway but i found the problem: it had a bad manifold intake gasket, which caused that cylander to not have enough air which made the fuel unable to combust which was why it was running rich with soot in the exhaust. Easy as that. If you know anyone else with this problem let em know this info.
Charecter1
11-06-2023 10:08 AM
Sleaker
08-26-2020 06:03 AM
Eggslinger
06-08-2019 03:32 PM
Seattle_Sign_Guy
07-12-2015 12:38 PM
Jnkml
07-06-2015 01:20 PM
Quick Reply: idle problems and cylinder misfire Plz Help!
