| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#26 (permalink) | |||||
__________________
4.3/5.0 Do iT!
#27 (permalink) |
You have low fuel psi. When you pinch off your return line you are almost doubling your fuel pumps psi. You could have a weak fuel pump or a restriction some where (lines, fuel filter...) 9 times out of 10 it's the electric fuel pump but you should check for restrictions first. At this point you need a fuel psi gauge.
Also because you have some wiring problems it would be a very good idea to double check any and all wiring related to the fuel control sytem (cold start vave, c.t.s. a.f.m. t.p.s. e.c.m.) I Hope this helps. Last edited by smar06; 01-22-2007 at 07:57 AM. |
#28 (permalink) |
Low fuel pressure might be the problem, but any lean condition would benefit from an increase in fuel pressure caused by pinching off the return line. And if the fuel pump were the culprit then it is unlikely that pinching off the return line would even increase the fuel pressure.
First check for air leaks, especially in the intake tract between the air flow sensor and the throttle. Then you should check the fuel pressure. if it is low then you'll need to find out why. If you can get it up to spec by pinching off the return line then look at the pressure regulator first. If the pressure won't go over 60psi or so with the return line pinched off then look at the fuel pump or circuit. Keep in mind that a weak fuel pump could be so due to a resistance issue in the electrical circuit causing an excessive voltage drop to the pump. Then test the coolant temp sensor. the best way to do this is to check the voltage a the THW terminal at the ECM. Back-probe the connector with a small diameter probe. You should have 2-3V there when cold (temperature dependent) and as the engine warms up it should drop to around 0.5V when fully warmed up If that is OK then you'll want to check the airflow sensor. If all that is OK then you'll want to check that O2 sensor operation These are the things that have the biggest effect on fuel mixture and the most likely to cause a drivability issue as bad as you describe. Having a bunch of hacked up wires like you have found can be a good indication that there are other "gremlins" lurking. I'd be suprised to find that your problem is not electrical in nature.
__________________
Targetnut don't talk about it, just do it! Precision Import Service '93 2WD 22RE, Ported w/os valves, custom intake manifold, crane cam,Megasquirt, 295cc injctrs, Supra fuel pump, adj fuel pres reg, 70mm throttle, LCE header, V6 Taco cat, 14lb flywheel, Kevlar clutch, W58 and short shifter, 4.10 gears w/Truetrac, drop spindles and blocks, 245/50-16 Yokos on 16x8 wheels, 4WD fenders, bumper, and valence, skinned tailgate |
#29 (permalink) |
You may also want to check your throttle bore if nobody else has mentioned it. They can get gummed up with carbon and oil from crank case. Take your intake piping off and look at your throttle bore, if it is black and dirty looking some carb cleaner and a rag will fix ya right up, clean it off and give it a shot. A gummed up throttle bore will definately make it idle poorly. Be careful not to spray too much into your intake if you clean it and just be gentle starting it, it probably wont want to start at first from the excess carb cleaner but will eventually. Thats my 2 cents.
__________________
'94 Single Cab 4x4 Pickup Turbocharged/Modified 22RE SDS EFI System Std 5spd 31x10.50 BFG's |
#30 (permalink) |
__________________
1988 Xtra Cab Pickup ('94 22RE; 4x4; 5spd) Rancho lift w/ 33x12.5x15 tires & 5.29s |
#31 (permalink) |
I think we can all agree that the wiring has to be a large part of the problem. Now I'm kind of new to this site and I don't know anybody here. So to get an idea of whats going on with your truck I would like to know a few things about it.
Did these problems just start. Was there some recent work done & then the problems started The cut wires are they because of recent work Has the truck been out of service for a while ???? |
#32 (permalink) |
we fixed some wiring, now it will start no problem it just wont run with out revving it up.... it will bog down and then die. ill take a look at that thanks.
__________________
4.3/5.0 Do iT!
#33 (permalink) |
truck has sat for a good 7 months, in the garage, it has a new engine in it, we swapped over the engine, but kept the comp and wiring harness, the two connectors on the front were different, so i spliced them using butt connectors, which didnt work so we just spliced them and now it will start just not stay running unless im giving it gas. it was timed at a higher than average idle.
__________________
4.3/5.0 Do iT!
#34 (permalink) |
i have 8 Check engine codes.... Im thinking bad CPU? and mass airflow sensor.
__________________
4.3/5.0 Do iT!
#35 (permalink) |
Some or most of those codes may have been set when you were trying to run the truck with all the wiring problems. Plus if you were disconecting any senser plugs while running like the tps or cts that will set codes. The codes will be stored in the ecm memory so you need to erase the old codes 1st. then run the truck and see what codes are set now. I think Toyota says to remove the ecm fuse for x amount of time but I've always just disconected the neg battery cable for 60 sec.
#36 (permalink) |
Rule out your EGR this way. Disconnect at plenum, will require the unbolting bolts for EGR mount, pull the unit out of plenum and cork hole. Then try starting. If better, your done. You've just by-passed your EGR , thus proving it's malfunction. This is symptomatic of EGR failure, sorry, forgot.
#37 (permalink) |
cool, i will pull the neg cable and efi fuse and let the codes reset, i hope its not true about all 8 lol if that doesnt help ill disengage the egr.
THANKS keep the ideas coming.
__________________
4.3/5.0 Do iT!
#38 (permalink) |
Before removing the EGR valve first unplug the vacuum hose that goes to it. Along with your hacked up wiring someone may have mis-routed the vacuum hoses and ended up with manifold vacuum running directly to the EGR valve causing it to stay open at idle which would result in stalling.
__________________
#39 (permalink) |
do you have a vaccum hose diagram for an 89 4runner? 22re 4wd, 5spd. federal model?
THanks ill try that too.
__________________
4.3/5.0 Do iT!
#40 (permalink) |
you should have a diagram under your hood
__________________
| Tags |
| 22re, bad, cpu, efi, fuse, megasquirt, oil, pressure, sender |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Idle Issue | JEBSR5 | 86-95 Trucks & 4Runners | 25 | 03-16-2007 06:05 PM |
| 22RE Idle Issue | blb | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 01-02-2006 02:32 PM |
| 22RE idle issue? | dave151 | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 10-24-2005 12:48 PM |
| idle issue | jayson161 | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 12-13-2004 08:57 PM |
| Idle spped issue | markjs | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 01-03-2004 02:32 AM |
