Identify this hose
Old 09-29-2015, 03:51 AM
wberry85's Avatar
Identify this hose
Can anyone tell me what this coolant hose is and where I can get another one?
It runs from thermostat housing to the front of intake. I have a piece of fuel injection hose in its place right now. Will that work or do I need to have real coolant hose?
Old 09-29-2015, 05:27 AM
scope103's Avatar
On some models of the 3VZE, there is a "water bypass hose" from the "water outlet" (not the thermostat housing) to the intake manifold. http://www.toyotapartsoverstock.com/...rimLevel=18292 About $20.
But you haven't told us anything about your vehicle (other than year), so I'm guessing.
Old 09-29-2015, 05:50 AM
wberry85's Avatar
Sorry, truck is in my sig. Its a 91 pickup 22RE.
I think it is the bypass hose but the one in the picture isnt bent quite the same way.
Old 09-30-2015, 09:27 AM
Squad 51's Avatar
That sure looks like the water bybass hose from the engine near the thermostat to the throttle body. I am looking for the part number, and if I find it I will let ya know. I don't think a piece of vacuum hose will do the job, but I bet you could get away with a chunk of waterline - I have done that in the past.
Old 09-30-2015, 10:14 AM
wberry85's Avatar
That is exactly what it is. I cant find a part # for it.
Old 10-01-2015, 07:41 AM
scope103's Avatar
Is it 16264-35030 ? http://www.toyotapartsoverstock.com/...626435030.html
I don't know much about the 22re, but this hose goes to the Aux Air Valve assembly. A photo of the installed location might have helped someone who DOES know the 22re to figure it out.
Old 10-01-2015, 09:08 AM
mikesnyhere's Avatar
i been running fuel line for 4 years for that same hose , i blew on freeway , side of road repair . i have the replacement in the truck. just never have installed it . in fact i have most coolant hoses in the 4r just incase .
Old 10-01-2015, 11:06 AM
wberry85's Avatar
Yeah a couple of other forums said that the fuel injection hose would be just fine so I'll just run it. I am lucky I blew the hose on the street rather than on a trail. I'll be adding various hoses to my trail kit.
Old 05-17-2016, 05:45 PM
update on the trail fix fuel line hose for a coolant line . it finally failed about 5 years after install !! that genuine Toyota replacement finally was installed !
kawazx636
10-06-2021 03:03 PM
ladybugRC
458
08-21-2020 10:41 AM
kcaudill
10-10-2015 02:39 PM
Matthew Perez
09-28-2015 05:43 PM
taraf
09-25-2015 02:57 PM
Quick Reply: Identify this hose
