i wanna hear some motor oil arguments
Old 11-20-2009, 10:43 AM
  #101
Smelliottkuhn's Avatar
I usually run 10-40w Castrol GTX in my 22RE, but I can't find down here in Mexico City. Everything they run is straight 40w. Anyone ever run this in their 22re? I need an oil change bad, and I am hesitant to change up the oil.
Old 11-20-2009, 01:03 PM
  #102
Teuf's Avatar
I would go with a good 10/40......... even a 5/30 syn blend,,,, in my reading its all about start up oil viscosity.
Old 11-20-2009, 01:04 PM
  #103
Teuf's Avatar
Valvoline, Penzoil?
Old 11-20-2009, 01:21 PM
  #104
tj884Rdlx's Avatar
Originally Posted by 89pickupsr5
what kind of motor oil do you use and why?
i'll use any hi mileage semi synth, 20w50 in the hot hot summer, 10w40 all year otherwise. if its super cold for a month in the winter, and i hear too much valve chatter in the a.m., i'll go with 10w30 when i next add a little.
i have a leak at the rear main, i try to use the hi-mi for the gasket swelling additives to deter other leaks. i usually go with the valvoline, but i'll castrol or penzoil if they're all that's avail, or on sale.
i change every 4-5000mi. but it has a self-refreshing feature of 1/2 qt. per month with that main seal leak.
i
Old 11-20-2009, 01:24 PM
  #105
tj884Rdlx's Avatar
you can't find any multi-grade? that sucks.
i guess if there's no winter a single weight will be ok, but i'd want that thinner viscosity available at startup.
but fresh oil is better than dirty oil. don't wait too long! can you buy a case online and ship it in?
Old 11-20-2009, 01:25 PM
  #106
tj884Rdlx's Avatar
Originally Posted by red1983
I am in love with AMSOIL 10W-30. In the past I tried mobile 1 and I burnt/ leaked a lot. It got dirty fast and I had a lifter tick while I used it. So, I wasn't impressed with Mobile 1. Other than AMSOIL, I liked Castol Syntec better out of the "store brands". Next oil change (15,000 miles from now) I think I will try AMSOIL signature series 0W-30.
do you a user only, or do you also distribute it?
Old 11-20-2009, 01:45 PM
  #107
greatskiiiier's Avatar
ok, coming from over 30 years in the business (my dads opinion, motor oil salesmen since mid/late 70s)
Mobil 1 all the way, viscosity is dependent on model and age, but ALWAYS Mobil 1. Period.
However, if its a used car which didnt use Mobil 1, then stick to conventional oil, synthetic is too good at its job and will clean out gunk and grime thats clogging up hole in oil pan and such causing an oil leak
Old 11-20-2009, 02:52 PM
  #108
MaK92-4RnR's Avatar
I use 5w-30 castrol synthetic... been using it since 107k
Old 11-20-2009, 03:01 PM
  #109
Teuf's Avatar
I believe thats a myth of sorts, the leaking after syn fill. And I think still an 5/30 is to heavy for start ups, (5) < the 30/40/50 or whatever is when its warm. And once to op temp, lets say 212, most all oils become a 30, within reason mind you. Like I said I am going to a syn blend , i'll see how it goes, and I do have a bit of a leak out the front main.
Old 11-20-2009, 06:22 PM
  #110
93yotaSR5's Avatar
i have always used castrol 10/30 in all of my vehicles.
Old 11-21-2009, 06:51 AM
  #111
depending on the motor 5 at startup is too thin... race cars use 0-weight because they're made to such high tolerances, a motor built in the mid 90s wasnt held to .0001 standards, maybe .003, in that case you need a thicker oil and higher pressure to push the oil.. the thin stuff will leak
and as for not being an expert- no hes not, but he knows who the experts are, talks to them, and learns, then makes arguments based on what they say.. and race cars are using 0-weight Mobil 1 mind you
As stated, im not an expert, my fathers not an expert, but this is what ive been told BY the experts (even diff brand reps agree on some things)
Old 11-21-2009, 09:44 AM
  #112
Teuf's Avatar
Sure oil pressure is high, if you are pushing peanut butter, and its hardly moving. Lower oil pressure with say 5/30 is low because its flowing, FLOW= lubrication and cooling.
PS: check out (sorry no link) ferrarichat / Dr. Ali E. Haas
bigjstang
08-25-2021 12:41 AM
09-04-2015 09:27 AM
Coreyr384
07-10-2015 11:13 AM
Huntingtruckcletus
07-08-2015 05:26 PM
karbin
07-05-2015 11:37 PM
Quick Reply: i wanna hear some motor oil arguments
