I need some help hooking up my tach
Old 09-13-2006, 03:02 PM
yotakid825's Avatar
Question I need some help hooking up my tach
I finally got a tach for my truck('94. came without a tach) and I'm doing this for the first time so I could use a little help. there are 4 wires caming out of the tach: a red(power), black(ground), white(light), and green(goes to engine). it says I'm suposed to splice the while into the gauge cluster harnes so I pulled apart the dash, but I have no clue what wire to splice into. and the green wire is suposed to splice into a black wire on the negitive side of the coil, but I don't know what side is the negitive side.
any help would be great.
Old 09-13-2006, 06:54 PM
LiquidSky's Avatar
I just intalled a new intrument cluster in my 89 toyota pickup. I didn't have a tach on my old when so I went to the local junk yard and picked a cluster with a tach from a 90 4 runner and installed it without messing with any wires and everything workes fine including the tach.
Here are some write ups hope this helps.
https://www.yotatech.com/forums/show...hlight=cluster
http://www.siestaoff-road.web1000.com/clustertech.html
http://www.mindspring.com/~jayk3/toyota/tachmod.htm
Old 09-13-2006, 07:01 PM
bodo's Avatar
Your coil is labeled - and + I have a 89' and if you're standing in front of it the - is on the left side.
Steven.m.paulk
06-07-2020 10:45 AM
smilen724
13
11-08-2015 04:11 PM
Jdgarrison
10-01-2015 05:22 PM
Jdgarrison
10-01-2015 02:11 PM
beltcutter
09-30-2015 06:14 AM
Quick Reply: I need some help hooking up my tach
