I need a pic of the bottom of a 22re intake manifold
Old 09-06-2010, 11:03 AM
pcowan's Avatar
I am installing a "new" engine in an 89 pickup and I can't get the coolant bypass tube done. It comes out of the back of the left side top of the timing chain cover and it has two branches. I found where the small branch goes but the large hose goes somewhere under the intake manifold. Of course the manifold and plenum and all the snakes of tubing are now done, so I have to feel around under the intake manifold to find out where to put that hose. It would be really helpful to see a diagram or pic ot the underside of that manifold, so I know what I am doing with that hose.
Polis.
Old 09-06-2010, 01:33 PM
snowhite's Avatar
Look up iamsuperbleeder in the member list and find his thread on rebuilding a 22re he took lots of pic's. Helped me out when I swapped my 22 for a fresh 22. Also with you having it in the easiest way to get to it is with the wheel off and the tube also goes behind the fuel filter at the top just a heads up if you have not done that already.
Old 09-06-2010, 01:38 PM
Teuf's Avatar
I was going to say the same thing. Superbleeder did a great pic job. Helped me do my head gasket change.
Old 09-06-2010, 02:22 PM
iamsuperbleeder's Avatar
https://www.yotatech.com/forums/f116...ctures-181237/
Old 09-06-2010, 02:54 PM
Teuf's Avatar
Cavalry to the rescue, Hi ho silver, Sighted sub / sank same, and all that rot.
Doug4320
03-24-2018 10:11 PM
05-20-2016 10:27 AM
kcaudill
07-20-2015 12:06 PM
87blyota
07-10-2015 04:31 AM
bryan34w
07-06-2015 05:53 PM
Quick Reply: I need a pic of the bottom of a 22re intake manifold
