I have a question about lifting up my 2WD automatic
Old Jul 2, 2008 | 07:41 AM
John911's Avatar
I was reccomended to get this by a yotatech member for my 1988 2wd truck
145$ Package D FB+RAD and 3‘’ body lift
http://www.4crawler.com/4x4/ForSale/...tml#TypicalKit
145$ 1 1/4'' lift Ball Joint spacers up front
http://www.4crawler.com/4x4/ForSale/...shtml#2WDor4WD
leaf spring LSPV bracket 1'' lift in the back 70$
http://www.4crawler.com/4x4/ForSale/Shackles.shtml
My question is, does this sound like like alls I need to buy for the lift? or do I need to buy shocks? if so what kind I looked it up for my truck and this is what came up http://www.bilstein.com/mistore/ymm_...reYMM=storeYMM
im not sure if i should by 4wd or 2wd shocks because of the lift.
Thanks,
John
Old Jul 2, 2008 | 12:16 PM
Robert m's Avatar
what size tires do you want to run? you going to crank the torsion bars at all? you plan on doing anything to the rear? or is that all you plan on doing?
to answer your question though yes you will need new shocks. you have to buy them for a 2wd because the 4x4 have different mounts. you will want about a 2'' longer shock for what you are doing. i have pro comps and would advise you to get something else.
also if your interested, in a few weeks i will have a set of fabtech upper arms that give like 2'' of lift that i will be selling for $80.
Old Jul 2, 2008 | 12:26 PM
4Crawler's Avatar
You would want shocks sized to fit the lift, that is measure the compressed and extended shock lengths needed and then buy a set to fit:
- http://www.4crawler.com/4x4/Rancho.shtml
Old Jul 2, 2008 | 12:35 PM
Fink's Avatar
Might try a search on this, I'm sure it's been talked about a handful of times.
On a more serious note:
4Crawler = Roger Brown = THE MAN
Fink
Flying91
45
Apr 11, 2024 04:39 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Sep 4, 2015 09:27 AM
hexrain
Jul 12, 2015 01:13 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
